Question about RCA RT2580 Theater System
No audio playing blu ray movie. previews on same disk play audio. using digital audio coaxial cable
    Brigadier General:
  • 8,546 Answers
I'm guessing there's an unnamed BluRay player in here somewhere. IT has audio settings and each movie might also have setups for the Main Feature. Previews and menus are always in the lowest common audio denominator.
This unit can only accept Doby-Digital or PCM digital audio. DTS, for example, is not supported.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2580-Receivers-manual/id/23292ag604/t/2/
As it says on page 4, "Read instructions carefully when connecting components to the receiver."
Read the Blu-Ray manual.
Posted on May 17, 2011
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
How do I play DVD on the BlueRay player?
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
Feb 02, 2011 | Vizio VBR231 Blu-Ray Player
We have a sony bdp 300 DVD. We updated the firmware several months ago and all the movies worked fine. However, now it will play just fine during the previews but when we play the movie, there is no audio....
Hi
This certainly looks like a potential firmware issue especially if the Audio is there on the previews. There are reports also of recent firmware updates causing problems on some other Sony BDP units.
You might want to try a Blueray cleaning disk which you can purchase from any good Audio store first to ensure there is not a problem with dirt on the lens that may be causing this. Simply insert and play like a normal disk and it provides a cleansing action to the lens.
Otherwise my advice is to contact Sony directly to discuss the matter and find out if there have been any recent firmware issues.
The most recent update for your unit is firmware version 4.9 and this was released on 12th June 2009
The support phone number for Sony Blueray Players is 239-768-7547
Hope this helps. Please do rate this answer. Many Thanks.
Sep 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Blu ray player wont play some movies
If you go to sharp global web site, choose your country then go to downloads to download update, can be done for cd or usb stick, if you use cd version can burn to disk using nero 9 which is availble as free trail on net. then put disk in player and it will update on own. should correct problem
Apr 08, 2009 | Sharp AQUOS Blu-ray Disc Player
Sony Blu-Ray plays preview but won't play the featured movie
try clicking on chapters to access the dvd
hope this helps
kind regards and don't forget to rate us please
Nov 28, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Digital audio problems
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
RCA RT2580 Theater System Logo
102 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
