Question about GE 27881 Phone
Model GE 27881 2,4 GHZ I have a problem with the base because it have not tone and when I pressed the speaker, the light does not switch on and the record said "Press number keys, to receive another instructions. o something like that, On the other hand , the corded hand set is ok, even I can do call. I cleaned the base, the corded hand set , the contact, I recharged the battery again without conection. I tried to explain to better because my language is the spanish not englishn
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Posted on Jul 07, 2007
  • 146 Answers
SOURCE: GE 5.8 ghz cordless model 25922
as with all devices which return to base for charging, the life of the re-chargeable batteries is shortened if it is constantly trickle-charged, so as with a moble phone, it is good to sometimes let it run down completely and re-charge as the battery charge will last longer, batteries are like muscles, they need excercise.
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: GE model 25881 5.8 GHz dual handset phone
DON'T hold the memo key. Use the book for set up instructions. Took me about 6 times to figure this out!
Posted on Sep 07, 2008
  • 160 Answers
SOURCE: My answering system and my instructions are all in won't pick up
is the incoming phone line plugged into the answering machine directly? the answering machine should then be plugged into the phone. the signal comes through the answering machine then to the phone. you may have the connections reversed on the answering machine. check those connections.
Posted on Nov 26, 2008
SOURCE: language,
I have the uniden cordless 6.0, series 1580. I mistakedly set the wrong language. How do I set it back to english?
Posted on Nov 29, 2008
Dont know how to put speaker phone on
Press the SPEAKER/CALL BACK button. Full details are on page 18 of the manual.
Oct 29, 2012 | GE 27881 Phone
Ticking sound during calls on ge cordless phones 2
it must be a humming sound what you are talking about if its that you need to replace the adapter .
Aug 27, 2009 | GE 27881 Phone
I believe they work on different frequencies. but am not positive.I've seen other people try it and it didn't work for them.
Mar 31, 2009 | GE 21905FE1 Cordless Phone
GE 2.4 GHz cordless telephone problem
Hi there, maybe I can help;
Is the phone base plugged into an switched outlet and is the switch off?
Let me know if I helped
Jan 06, 2009 | GE 21008GE2 Dual-Handset Cordless...
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
Sep 02, 2008 | GE 26998GE1 Cordless Phone
GE 5.8 ghz cordless phone
the menu will take you to registering the hand sets to the base unit
by deleting incoming calls you have disconnected from the line
follow the instructions in the user manual to get reconnected
if you do not have the user manual , go google and type in --user manual for ge ( model ) cordless phone --and down load the pdf version
May 25, 2017 | GE 27957GE1 Phone
GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Feb 22, 2008 | Lands Phones
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
GE 27881 Phone Logo
41 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
