Question about HP Compaq nx6310 Notebook
Power my laptop had a charger problem, i changed it and now it does not poewer on i have tried several chargers and the problem still persits. please help me out. heeeeeeeeeeeeeeeeeeelp
I think I have the same problem. Having spoken to a few people, everything suggests that it could be a faulty jack plug or a soldered joit that has come adrift on the jack plug. It is quite a common fault apparently. Could be expensive unless you feel competent to dissassemble your machine and attempt the repair yourself.
Posted on Aug 28, 2008
SOURCE:
I have garmin nuvi760 gps when ever I hook it up in my car fuse in car charger cable blown up, I changed the fuse several time ,it does the same thing,it takes 3amp 250V fuse.I realy need help.
You need to determine if it is a charger problem or a problem in the Nuvi.
If you have the AC wall charger, plug that into your Nuvi. If the unit boots normally, then you can discount that there is a problem with the Nuvi. Does the Nuvi power up on its own internal battery with the charger disconnected? When you change the fuse and it blows, is the charger plugged into the Nuvi?
Try changing the fuse and powering up the charger without it being plugged into the Nuvi. If the fuse still blows, then the fault is with the charger. Please also be aware that the charger converts +12VDC from the car battery to +5VDC to power the Nuvi. Some chargers can fail and provide +12VDC directly to the Nuvi. This can damage the Nuvi and will certainly blow the fuse.
Sep 23, 2015 | Garmin nuvi GPS
My Acer Aspire won't recognize the battery charger. I plug it in and nothing happens. After I unplug and re-plug it back in several times, sometimes my computer will recognize it and will start to...
Try wiggling the plug around a bit to see if you can get contact. You could also try borrowing a power supply if you know someone with the same machine to isolate the problem.
Oct 16, 2013 | Lifetime Acer Aspire 4810TZ-4011...
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
My dell studio 1737 has gone dead.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Many people have reflected that Dell's notebook haven't recognised and charged the new battery problem. Usually, they solve this problem via BIOS refreshed.
Usually, please connect the battert with the power supply when you can refresh the BIOS. You can download the BIOS program from Dell support website http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=dell+bios+inspiron+6400&cat=sup, automatically installed and automatically restart till to complete. Of course, you could check its use manual in advance.
Or you can visit http://www.batteriescenter.com.au/.
Mar 25, 2012 | Dell Studio 1737 Laptop
I got a 7" mini
1.make sure that the charger is the same.
2.if it's the same then you need to replace the battery.
3.our can cross check your charger with your friends 7"min if he has one !!!
happy computing !!!
Jun 18, 2011 | Computers & Internet
Computer does not recoginze the ac power supply and will not charge the battery
Dell laptops are notorious for wanting the exact model of charger they are designed for. Simply, they will not run on a non-genuine Dell chargers as far as charging is concerned.
IF you are already using a genuine Dell charger, for that models amperage and voltage, there is an issue with the charging circuit on the motherboard
Jan 12, 2011 | Dell Studio 1737 Laptop
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
Oct 31, 2010 | HP Compaq nx5000 Notebook
My sony vgn sz330 doesnt hold a battery charge, i have bought 2 replacement batteries but they all do the same thing
Your symptoms point to two possible problems.
1. It's your charger that's the problem. Chargers can fail in one portion of their structure that charges the battery but the part that powers the laptop directly can continue to function normally.
2. Your DC Power Jack (the small hole where the charger plugs into the board) can be having the same trouble I described in the charger
When people bring a laptop to my shop with these systems I always try a charger first, the easiest and least expensive fix. If that doesn't work, I have to send the laptop out to one of several vendors on eBay that specialize in that repair alone. You just go to eBay and type "DC Power Jack Repair" in the search box and you'll have quite a few reapir shops to choose from. I've had 100% success with several different ones.
Good Luck
Jul 31, 2010 | Sony VAIO VGN-SZ330P/B Notebook
How do i fix my power cord for hp pavillian zd 8000 i need to re solder to the board
Just open the charger case (It might be void your warranty!) and re-solder it with a very good lead on your charger PC-Board, please doi it very carefully! If you think you cannot do this, just buy another laptop charger, better buy an "UNIVERSAL laptop charger" that come with several lead-jack and a variable output voltage. Remember, this part is very important, otherwise it will damage your laptop in a whole! GoodLuck!
May 11, 2009 | Computers & Internet
Radio will not stay charged. Battery replaced. Problem persits.
Does it look like the charger is working?
Batteries have a life of 1-5 years depending on how they are used. Check ebay for a new set of batteries.
Jan 14, 2009 | Maxon GMRS50 (16 Channels) 2-Way Radio
HP Compaq nx6310 Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
