I have an error code: 0F55 on my Konica Minolta Bizub C35
  • Chris Banzet
    Chris Banzet Jan 20, 2016
    Listed below you'll see the exact details listed by fuzzyg for checking the "fuser unit", however, many do not have the skillset to do this and the fuser unit itself is more than likely bad. Even if its not, the cost of repairing the fuser unit is about equal to what you'll pay a technician to repair it. Keep this in mind, any technician who said they can do it cheaper will be lying to you! Just pay the $200 and replace the unit. This way everything within the unit is brand new and you won't have to worry. Saving $40 or whatever a tech tries to convince you he can do it for, isn't worth it. Just replace the Fusing unit. Here is a reference for purchasing a fusing unit -http://www.quikshiptoner.com/catalog/kon...
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
firecontrol7
  • 6161 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Posted on Jul 19, 2009
  • 97 Answers
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
Pls help on how to clear error 0310 on bizhub c20 i have checked all the connection and my print head is ok what next shuld i do to remove this error pls is very urgent thanksa
You didn't say what make of printer it is. Error codes vary from printer make to printer make. Your best bet is to do a Google search for ERROR CODE 0310 NAME (NAME=name of printer).
If It's a Konica Minolta read the link below:
Konica Minolta Bizhub C35 Error Codes
Feb 17, 2016 | Office Equipment & Supplies
How do i fix error code 13DD ON KONICA MINOLTA BIZHUB C35
The counter data on one card does not match counter data on a different board did some one try to reset the counters to make the machine newer???? Need to get tech out to try and rewrite the firmware,
Jun 30, 2015 | Konica Minolta Bizhub C35 Multifunction...
How to c35 chip cencer error disbled than running for machine
Re: error code 0094 on a Konica Minolta C35
Make sure the second transfer release solenoid isn't hanging up due to the pad that's there to minimize noise. See the attached pic. This pad had gotten sticky enough that it was delaying the action of the solenoid. Took a lot of service calls to figure this out!
paperclip.png Attached images
Oct 29, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Error p5 in konica minolta c450
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed..
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
Error code C-3505 Konica Minolta Bizub C6500
This is a fuser code, which needs reset by your service provider in service modes, let me
Dec 28, 2009 | Office Equipment & Supplies
1,728 people viewed this question
jasbo
jasbo
