Question about Ovens
I had an home energy audit done and the carbon monoxide level reading was 266 parts per million, which the auditor was way too high. Is this a high level for a ARGS7650 gas oven or within the specifications for this model?
    Scholar:
  • 52 Answers
The oven is not burning properly, you require a service on the appliance by a gas registered engineer, as this is specialised area that requires special equipment without getting into this too far, it should cost depending on location, around £50, if you have a gas boiler the same engineer can offer this service.
Hope this has been helpful.
John
Posted on May 17, 2011
Need glass cover for oven bulb
What type of oven is it? How old is it? Model#
Suggest asking for help at Home Depot first.
May 15, 2017 | Ovens
Need to know the cooking time and temp in C in fan forced oven for pork loin roll weighing 1.22kg
usually 40 minutes per 500 grams at 180 degrees C
so 1 and a half hours plus preheat the oven .
And it is thawed not frozen
don't just take my word for it read it on link below
http://www.pork.com.au/home-page-consumer/recipes/cooking-instructions.aspx
Dec 24, 2016 | Ovens
Oven flame is yellow
There is an adjustment on the burner assuming that the top side burners are ok. Getting to that adjustment may be a pain, so look for a screw on the metal sleeve on the end that the gas line connects to. this sleeve controls the amount of air that mixes with the gas to produce a hot flame. Do not let this go, because the amount of carbon monoxide the oven produces now can be lethal.
Feb 21, 2014 | Ovens
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
Carbon monoxcide smell when oven running ?
I have to assume your oven is gas-fired but it helps to have make and model info.Carbon monoxide is odor- and colorless; that's why its dangerous. I don't doubt that you have poor combustion and it may well contain the gas in the fumes. Check for yellow flames which are a sure sign of an improper gas-to-air ratio. If you do, you may have a buildup of residue causing the problem.
Dec 27, 2011 | Ovens
Carbon monixcide smell when running ??
Carbon monoxide is both odor- and colorless, making it very dangerous. It has no characteristic odor.
Dec 27, 2011 | Blodgett DFG-100 Gas Single Oven
I had my stove checked as part of an energy audit, and they reported that it was putting out 400+ppm of CO. How can i fix this as 2 appliance repairmen have stated that they can't.
That is the standard CO production of many ovens....
For some reason there is no requirement for a check of them and no limits for them... yeah it's nuts...
Also there is no adjustment on most so there is no way to correct it...
Just make sure you ventilate the room when using the oven... that is the best you can do....
If you choose to buy a new one it will probably be just as bad...
heatman101
Mar 04, 2011 | Ovens
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    Strong Foul smell coming from oven only when I turn it on
    do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
    Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
    Microwave will turn on but not heat
    Test the high voltage capacitor, the rectifier diode.or the magnetron.
    If it additionally does not spin and no light, then check also the door switch.
    The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
    Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
    All locations, and description of this parts can be located using the diagram here: Counter top.
    Parts must be tested to find out what is wrong.
    Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
    A microwave energy leakage test must always be performed when the oven is serviced for any reason.
    Regarding parts, contact the seller here to purchase parts. (here in UK).
    Nov 26, 2007 | GE JTP85 Electric Double Oven
    Ovens Logo
    76 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
