Question about Gateway 552GE PC Desktop
My dvd will not eject or reconise a disk - Gateway 552GE PC Desktop
  • 621 Answers
Sounds like you need a new one. If theres a disk in there which you need you will see a very small hole on the front of it which is an emergency eject. I normally straighten out a paper clip and poke it in. A new DVD copier is only about $25 and very easy to install only 2 plugs which can only go in one way. If youre not confident doing it yourself its only about 10 mins work so any shop should not charge too much. Cheers and please vote
Posted on May 18, 2011
Ejectiing a disc
f you're told you can't eject a disk, try the following suggestions.
f you're trying to eject an external disk:
  • Choose Apple menu > Log Out, and then log in again. Try to eject the disk again.
  • If you still can't eject the disk, choose Apple menu > Shut Down. Disconnect the disk from your computer, and then start up your computer again.
    If you're trying to eject a CD or DVD:
    • Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
    • If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
      If you're trying to eject a network disk:
      Choose Apple menu > Log Out, and then log in again. The network disk should be gone.
Jun 11, 2012 | Apple Air Computers & Internet
Need to eject
If you're told you can't eject a disk, try the following suggestions..
Jun 11, 2012 | Apple Computers & Internet
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
IMac5,1 DVD-R won't eject.
restart mac and hold down the mouse after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
Hope this helps.
Oct 30, 2009 | Computers & Internet
My dvd drive doesnt reconise disks when they are in the drive
2 things that u have to check
1) Is your DVD disks damage so u cannot read it?
2) Is your DVD drive spoil so cannot read your DVD?
To check condition 1), u may try insert other "good" DVD to make sure your DVD drive may read it. If your DVD drive can read other DVD so this mean your current DVD disks are damage.
To check condition 2), u may try load your DVD disks using other laptop. If your DVD show readable on other laptop, then this mean your current DVD drive is spoil or may have poor lens sensibility. Try to clean your DVD drive or replace a new 1 if necessary.
YBC (/\)
Oct 02, 2009 | Acer Aspire 3050-1733 Notebook
Cant get my acer to burn dvds it doesnt reconise the blank disk
Ok, Here the issue, A lot DVD media are out side not good. To use your burner try to install original software came with it(Poss.NERO)
If you can't try to use older version, Vista is not working for most burners. You need XP. ALso look for dvd43 and install it. You need this.
You may also need some codecs that works with burners, Media as Taiyo Yuden suggested. check smartmediacom for more informations.Specially media troubles section.
JMC
Aug 18, 2009 | Acer Aspire 4930-6862 Laptop
My DVD RW says some DVD-R's are CD-R's
make sure the disks are +- - + compatable to your burner
Jul 08, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
I inserted a disc (dvd) it will not eject. any
If the disk will not eject but however you got full power to the dvd rom then the dvd rom will need to be removed from the laptop and then opened up to manaul eject the disk.
Jun 30, 2009 | Dell Studio 15 Laptop
My pioner dvd dr 1120 d wont reconise blank dvd's
Open it with NERO softwer and add some files to burn, down at the right end of window (nero's) have a line that says how much space on disc there is.
Simple as this, I just caimed from my DVD dealer and he explained to me, Empty disc will always say 0 Bytes but if you open Nero Burner you'll be able to se how much of space is free on scale, after and whille adding files to burn image.
Hope you understand me :)
Sep 29, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Gateway 552GE PC Desktop Logo
172 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
