SOURCE: epson stylus photo 1400 paper feed
I have the same problems. Very frustrated. Has anyone found a solution to this??
SOURCE: Photo Paper Feed
hi,
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
adonscott
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
you can try and reset the printer with software let me no if you dont haver it
SOURCE: epson stylus 1400 service utility SSC
The free SSC utility which will reset the waste ink pad protection counter in most Epson inkjet printers can be downloaded from
http://www.ssclg.com/epsone.shtml. Remember though, if you don't change the ink pads, there will be an increasing danger of ink leakage from your printer, particularly if you tip it up for any reason - VERY messy, and it can clog up your printer mechanisms.
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
