Question about Kenmore Washing Machines
Clothes are still quite wet after spin cycle, although the machine spins.
  • 3 more comments
  • ordure May 18, 2011
    Apparently you didn't receive the information that the machine is a Kenmore top loader (specifically a 110.15942400). I checked the items you noted - none of these are the problem. Can you suggest anything else?
  • ordure May 19, 2011
    It seems that the P.S. could be the problem. During the spin cycle the flow from the drain hose is very slow.
    The price of the part is about $100 - the question is whether replacement of this part is makes sense for a six year old machine, since it is probable that other parts are likely to be wearing out. Do you think it is time to replace the machine?
    P.S. There is a problem with the Sears parts web site - the link you provide doesn't load properly.
  • ordure May 20, 2011
    I opened the machine to inspect the Water Level switch (or P.S. switch). There was no clog in the plastic tube, and the other end, at the tube looked fairly clear. Just to be sure, after reassembling the machine, I ran a small wash with just detergent (no clothes). At the end of the cycle, there was still water in the tub - I ran the spin cycle again, and the water slowly came out the drain hose.
    The Water Level switch will cost me $100 - it would be easy enough to replace it, if this will solve the problem. I already checked the tube, which seemed fine, so I only would have to open the control panel. Are there any other parts that could cause problem (the pump, for example). I checked for motor coupling problems - the tub spins when I open the cover midway in the spin cycle. Since there is water remaining in the tub that has not drained when I ran the machine without clothes, it doesn't seem to be a spin cycle problem. I checked the drain hose by running water through it from a hose outlet - it flows nicely. There doesn't appear to be anything stuck in the drain inside the machine. The water-inlet valve is not leaking.
    Please let me know if you believe replacing the Water Level switch is the answer to my problem.
    Thank you.
  • ordure Jun 02, 2011
    After your last comment I discovered that, after I returned the machine to its place, there was a crimp in the hose. I rearranged the hose to remove the crimp, and the problem was solved. The problem returned yesterday. By running another spin cycle, I was able to remove most of the water.
    Today I found wet clothes at the end of the cycle. I attempted to run another spin cycle, but found the agitator was not turning. Does this mean that the motor coupling has failed? Is it possible that a failing motor coupling was the source of the problem all along?
  • ordure Jun 05, 2011
    I replaced the Motor Coupling, and the machine spins, but the clothes are still too wet. The drain hose seem to be in order. Could I have a transmission problem, and, if so, how do I test for it, and repair the problem?
  • Kenmore Master
  • 19,396 Answers
Hi.
The problem is often the pressure switch that detects water level and decides when to stop the pump.
The pressure switch is located on control panel . It is a round shaped plastic part that is connected to wires and to a long thin rubber hose going inside the tub.
The P.S. is difficult to test, then before replacing it check the rest.
Check the drain hose height setting. If hose is not well placed you get water back inside the tub. Do a test with drain hose down in a bucket. Check the drain pump , disconnect hose from pump and remove blockage if any. The pump is accessed from the bottom of the appliance.
After checking all that, clean or replace the pressure switch.
Disconnect power before performing maintenance.
Regards.
Ginko
Here parts and diagrams.
Posted on May 19, 2011
  • 2 more comments
  • Ginko
    Ginko May 19, 2011
    Hi.
    The pressure switch is difficult to test. Testing is done reading Ohms with tub full and empty. The technician will rarely test it.
    Before replacing the pressure switch try cleaning the hose connected to the switch. There was also an old trick of blowing into the switch to make click a stuck switch (manufacturer says not to do this as you risk to break a good switch). Clean also the switch inlet. Most of the problems with pressure switch are given by detergent blocking the switch.
    Here SEARS website, enter the model number: http://www.searspartsdirect.com/partsdir...
  • Ginko
    Ginko May 20, 2011
    Re: "I ran the spin cycle again, and the water slowly came out the drain hose."
    The water is supposed to be pumped out, not to come out slowly. Check for blockage and observe if the pump is working. I did not insist on the pump because it is usually easy to notice if pump is coming on.
    Also be sure that you have done the test with drain hose in a bucket. As suggested.
  • Ginko
    Ginko Jun 02, 2011
    Motor coupling can cause no agitate and no spin but cannot be the cause for no drain. There may be more than one problem.Incorrect drain hose settings may have been the reason for drain problem, If the washer has been moved, there may be a wiring problem causing the agitate problem.
  • Ginko
    Ginko Jun 05, 2011
    The fact is that a transmission problem will not result in wet clothes. Check if machine is spinning. It it does not spin, then you may have a transmission problem. If the machine does spin, and the agitating problem was due to motor coupler, then the transmission is OK.
    If the machine does not agitate, but only partially turns, then it can be the transmission.
    The transmission is a part that does not fail quite often.
    Do a new test, with the drain hose down in a bucket. Check also that drain pump is starting and working. If clothes are not wet with drain hose down, then you still have a problem with drain hose settings.
  • 6,993 Answers
When the clothes are wet at the end of a cycle, check these: Motor coupler, Spin cycle, Siphoning and Water-inlet valve.
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
I hope you found the above helpful.
Regards.
Posted on May 18, 2011
  • Walesarumi
    Walesarumi May 19, 2011
    This is what you need to consider; You need to compare the cost of repairing the unit with the cost of getting another unit. The price difference between the cost of purchasing another unit and repairing the unit should determine whether the unit is worth fixing or not.
    So if the cost of buying the part/fixing is close to the cost of getting another unit, then it's not worth repairing. This means it's time you replace the machine. You can also check it the other way round.
    Also, check repairing history if the machine. That is, how often has the machine been repaired in the part?
    The above should determine whether it's time to replace the machine or not.
    I hope you understand the above.....
    Regards.
It doesn't spin dry the clothes like it use to. Although there is no water in the tub at the end of the cycle the cloths are quite wet
if the clothes are soaking wet, the tub isn't spinning. Have you stood at the machine and listened for the spin? solution may be as simple as a broken interlock switch. Let me know.
Jan 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Clothes wet....not spinning as fast.
Suggest you check and clean filter, if clear then check brushes in motor.
Please rate my solution.
Thanks.
Mar 23, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of...
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Jun 15, 2008 | Bosch Washing Machines
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine does not spin out all water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 02, 2008 | Washing Machines
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
183 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
