I must reprogram my tv each time I turn it on
  • 3,287 Answers
I'm assuming that you are powering the TV off with the remote, not by shutting off a device (such as a home theater system that it is plugged into) and having it disconnect the power from the cord. if this is how it is shut off, that will be your problem.
Likewise, you may have plugged the TV into an outlet that is operated by a wall switch. These are typically found in rooms that do not have an overhead light, and are designed to control a table lamp. Usually, the receptacle will have one outlet that is on all the time, and the other controlled by a wall switch. Check to make sure that the outlet that the TV is plugged into remains on all the time - regardless of the position of any wall switches.
The solution to both of the above issues is to plug the TV into an outlet that is on all the time. The interruption of household power to the TV is most likely causing the memory loss of the settings in the TV.
The other possibility may be the way you are shutting off the TV each night. Some TVs have an on / off function that works with the remote, but only if the standby power is on. If the standby power is off, the remote will not be able turn the TV on. Some manufacturers use different colored indicating lamps for Off, Standby On and TV On.
Without knowing your brand and model TV, I can't go deeper than that. You'll need to consult your TV manual to see if and how your TV works - or provide the brand and model info so we can see if we can find a solution if none of the above works for you. I hope this helps & good luck.
Posted on May 17, 2011
I have a problem with my thompson tv i can not turn my tv on or off with my romote or my fingers
Did you try unplugging and replugging the set to reset? Checking remote battery? Actuating each remote function (button by button) twice in succession to reprogram? Also, could you have inadvertently de-programmed by pushing the PROG or similar button? Mfrs not uncommonly but that button in the wrong place where users, especially button mashers, are apt to push them trying to turn of the set. The suggestions above might reprogram. Other wise contact customer service for the TV and let them guide you.
Nov 03, 2014 | Televison & Video
Tv will not come back on
Did you try turning the TV on with buttons on the TV itself and not the remote?
Dec 30, 2007 | Televison & Video
Antenna button not functioning on RCA300x universal remote
U have glitches in the reprograming back and forth.Take the battery out,about an hour.Reprograms the codes again,should work again.Don't reprograms the codes back and forth to many times or one times to many will kill the remote for good.U have 2 tvs,U should have 2 tvs remotes.
Jun 22, 2010 | RCA RCU300 Remote Control
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
Have a converter box. Had to change battery in remote and now tv will not turn off.Have a rca tv
hold the power on off button down and press the channel up button repeatedly up to 45 times until the tv set turns off.
Dec 11, 2009 | Insignia Digital-to-Analog Converter for...
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
May 04, 2009 | Toshiba Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
