Question about Frigidaire Washing Machines
I cant change the belt for the washing machine glgt1031cso
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Posted on Jul 25, 2010
What's your problem?i am trying to fit a drive belt to a hotpoint wma66p washing machine but cant stretch it around motor pulley and drum. i cant see a tensioner bolt. is there one?
There is no tensioner bolt as such; tension is just maintained by the motor support bolts. Please see my notes on belt changes ;-0)
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT AGAINST THE MOTOR OR FRAME; THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 23, 2011 | Washing Machines
Tip
Change the belt of a washing machine
It may happen that you have to reassemble a washing machine belt (belt is being broken or simply withdrawn from its normal location).<br /> With a change thinking about ordering the same belt model.<br /> The mounting is done of a bike chain:<br /> -Placer the belt on the motor axis and a part on the pulley.<br />loyalty turn the pulley.<br />-the belt will be implemented alone.<br /> <br /><img src="nidalkom01_11.jpg" />
on Jan 10, 2011 | Washing Machines
How do you change belt on clutch pully, old belt is there it did not break completely, but cant see how a new one would go on.
if the actual model is what you have on the page LSQ9564J,theres no belts on this machine as they are a direct drive machine and use a drive coupler to turn the transmission,not a belt
Sep 11, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Our washing machine spins, but it doesn't spin our clothes out. Everything comes out still very wet, even more so if it is a heavier load. It almost seems like it is being slowed down by something but we...
Change the belt, a worn belt causes the machine to spin slower.
Tilt the machine back and the belt is accessible underneath the machine, simply remove and replace no tools required.
Dec 26, 2009 | Admiral AW22 Top Load Washer
How doyou change a belt on a top loading washing
If you cant get to it from a cover on the front, It must be laid on its back or side to fix.
Oct 21, 2009 | Kenmore 22422 Top Load Washer
Cant get new drive belt to fit washing machine. right one but cant get it to stretch enough to fit from drum wheel to motor
this is a common problem as nowadays stretchy belts are used in order to avoid motor adjustment.
fitting requires some brute force. the way i do it is to put the belt on the motor pulley then start it as much as i can on the drum pulley. turn the drum pulley keeping force sideways to push the belt on and as you turn, the belt will go on
Oct 21, 2008 | Hoover Washing Machines
BOSCH WFMC2100/UC WASHING MACHINE
It tend up to be the control panel on the unit
Dec 02, 2007 | Bosch Nexxt 300 Series WFMC2201UC
Whirlpool wahsing machine
If yours is a whirlpool DIRECT DRIVE than it has no belt, may be why u cant seem to find one.
Dec 02, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
Washing machine
you shouldnt have to loosen it, if you put the belt on the motor first then onto the pulley, using both hands (one to keep belt on pulley the other to work the belt around) it should go on pretty quickly, maybe tight though.
hope this helps
kj
Nov 07, 2007 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
