I have received an unwanted Bush NE205PLL iPod Docking Micro System from a friend but without the manual. is there anywhere i can get one online? or can you tell me how to set up the time etc. many thanks
SOURCE: JBL on time
No luck finding repair, so have accepted that mini jack into ipod and aux-in socket in on-time will have to do. My daughter is satisfied!!
Posted on May 23, 2008
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Posted on Nov 30, 2008
SOURCE: I can not figure out
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Posted on Jan 05, 2009
SOURCE: ipod nano not charging on
for some **** reason the new ipod nano (4th generation) does not support FireWire and therefore will not charge on any docking station that is a FireWire power sorce - which seems to be most of them out there!
have same problem so will end up charging from computer as docking station still plays the new nano, no point in buying new docking station just for sake of charging!
Posted on Jan 16, 2009
  • 6 Answers
SOURCE: can you repair a broken ipod connector on the JBL On Time?
Yes it can
Fullers Electronics on 01728 746400
The board part number is: ZDTIMEWT0100G
Posted on May 06, 2009
Bush manual instructions
Hi I have just bought a second hand Bush Alarm Clock Radio with iPod and iPhone Docking CCR232i Black.
Unfortunately it doesn't have the manual and I have spent ages trying to find one on the het to no avail,
would anyone know where i can find one please.
Any help would be much appreciated :}
Jan 12, 2014 | Televison & Video
Setting up ipod video
According to page 34 of your owners manual, your docking station will only allow you to listen to audio from your iPod/iPhone. Video on your yamaha can only be viewed via composite, component and HDMI sources.
Apr 29, 2012 | Yamaha Audio Players & Recorders
How can i get a user manual for the Philips DCM 250/37
I suggest visit this link to download this PDF document: dcm250_37_pss_aen.pdf
Hope this helps (remember to rate and comment this answer).
Aug 17, 2011 | Philips DCM230/37 iPod Docking Executive...
Hi I have a wharfedale is73 ipod docking micro system and I cannot get my ipod classic to work on it. I have tried a different ipod on it and it works fine.
Unfortunately, there are many ipod docks that are not compatible with the full range of ipod generations. Usually the case is that on older docks newer ipods dont work and vice versa.
Hopefully this helps
Jan 07, 2011 | Audio Players & Recorders
Malfunctioning connection on ipod ''logitech pure-fi anywhere2''
phoned logitech today who have offered to replace the docking station free of charge as it was under warrenty.Will probably stick with them as a company
thanks for your offer of assistance will bear you in mind for a more complicated problem
Feb 08, 2010 | Logitech 984-000006 Pure-Fi Anywhere...
How can I hook up my ipod without the ipod docking
use your headphone jack, you will need an adapter cable that converts the signal to left / right male RCA jacks. (available at radio shack or on ebay)
these can plug into any red / white inputs EXCEPT phono I use the input labeled CD for my blackberry to listen to MP3's and stream music from Pandora.com
Dec 30, 2009 | Onkyo Tx-sr507 A/V Receiver
Sony Micro Hi Fi with iPod port ?!?
no it's not an ipod port ipod port a slightly bigger.
Dec 08, 2008 | Sony (TDM-NW1) Docking Station Adapter for...
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
169 people viewed this question
 Grubhead
Grubhead
