Question about Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine
Hi I just purchased a Singer Heavy Duty machine from Sewing USA and my upper thread has a problem picking up the bobbin thread, it won't pick up the thread from underneath at all. Usuall it winds around and picks it up. Thanks, Linda
    Novelist:
  • 233 Answers
Generally, this is because the needle is either inserted incorrectly or because it's bent. Even if it doesn't look bent, it can be ever so slightly that you can't even see it with the naked eye. See if changing the needle corrects the problem, and be sure to insert the needle with the flat side of the shaft facing away from you.
Good luck, Linda!
Posted on May 17, 2011
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
Having trouble picking up the thread from the bobbin
Try a brand new needle. Verify that the machine is threaded properly--both upper and bobbin threads.
If it is still not picking up the bobbin thread, it is likely there is a needle/hook timing issue requiring service.
May 17, 2016 | Singer 4411 Heavy Duty Sewing Machine
The bobbin thread will not pick up. How do I fix it?
First, install a brand new needle and verify that it is facing the correct way and it is the proper needle for your machine.
Confirm the bobbin has been installed in the bobbin case so it is unwinding the bobbin the proper direction as you pull the bobbin thread.
Six Common Sewing Machine Problems Solved
If it still will not pick up the bobbin thread, open the bobbin area of the machine and watch the needle action as you hand-turn the handwheel. You may see why it is not picking up the thread because the needle could be arriving too soon or too late to intercept the bobbin thread. If this is happening, the needle/hook is out of time. Take it for service.
May 11, 2016 | Singer 4423 Heavy Duty Sewing Machine
The bobbin thread won't pick up
this is all i can find out for you so not sure if this will help you out.
If it is not in the correct position, the needle will not go down and pick-up your bobbin thread. ... Also, make sure your bobbin is in correctly (not backwards) and that the upper tension disks of your machine arethreaded correctly. Make sure the presser foot is upwhen seating the thread through the upper tension.
Frequently Asked Questions ' Singer Sewing
www.singerco.com/support/frequently-asked-questions..
or go to this link might help you..
janome sewing machine won pick up bobbin thread Google Search
Oct 29, 2017 | Janome Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
Apr 02, 2012 | Singer Sewing Machines
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine Logo
319 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
