Question about Ovens
Oven not correct temp.. - Ovens
    Scholar:
  • 52 Answers
Is this an Electric oven !!
Johnf1
Posted on May 17, 2011
My oven temp is not keeping correct temps set at 350 and acutual temp cooks at 325?? problem correction?
Hey friend, I appreciate your post!
It sounds like your Frigidaire oven could need to be calibrated. If could also be an issue with you thermostat or control panel. In order to properly calibrate your oven you would need to seek assistance from a professional. I would also recommend seeking assistance from a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Oct 04, 2014 | Frigidaire Ovens
No temperature control in Oven, even with a new thermostat
If you are certain that is wired correctly, and is the same as the old one, having made sure you have got the sensor located correctly,then it should click off the element at the set temp.
If it does not, then that leads me to suspect that the new stat is either faulty, or the wiring is not as it should be,I do not forsee any other reason for it not to cut out.
Jan 16, 2010 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven burns things, very hot on bottom
The temp indicator light goes on and off according to the temp selected.
The sensor referred to is part and parcel of the the thermostat, or temp selector
the fact the light goes on and off, shows that the thermostatt is working, but neccesserily at the correct temp.I maintain that the thermostat that controls the temp is faulty, and needs to be replaced.
Dec 21, 2009 | Frigidaire FEB27S5A Electric Single Oven
Ge oven temp not correct after clean cycle
What are you cooking pizza. When you get at the high extreme most oven controls are not as accurate and have a wider differential. I assume the measurements are taken without opening the oven.
Dec 03, 2009 | GE Profile JTP56 Electric Double Oven
F2 on my gas oven
HI, This is a oven temp sensor failure code. The actual sensor should be replaced asap. This will correct the issue.
F-2(Oven Temp Sensor failure)
Oct 03, 2009 | Amana Ovens
Flashed F5 when temp is heating up
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
May 19, 2009 | Kenmore 47834 / 47832 / 47839 Electric...
Gas oven not heating
Hi, the oven temp sensor is not registering correct temp signals. i recommend replacing the oven temp sensor asap.
Mar 24, 2009 | Frigidare FGB24S5DC Gas Single Oven
Oven wont heat up to temp set
You will need to have the thermostat looked at or replaced, it may be defective and not reading the correct temp, also try using a manual oven thermometer to check the actual temp in the oven to give you a better idea of what the actual temp is inside
Jan 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
