Question about Vacuums
Hi. I bought a delonghi iron stirella. i did all what was wrtitten in the instruction but the button "lack of water" is still on and i have no idea what i have done wrong and what i should do to fix this problem. thanks you in advance, Paulina Rybak
2 Suggested Answers
mnwarfield10
  • 452 Answers
SOURCE: how do i change filter
take old one out /// fill new one with water but put finger under hole ... replace.
Posted on Feb 27, 2011
I have a model #4268-126 Iron, can't find my instructions to clean the iron, have very hard water and the steam does not work very well please help Thank you.
as with most electrical appliances that use water they need descaleing every so often, use a store bought descaler, read the instructions before useing/buying.
Sep 03, 2011 | Vacuums
The iron is emitting scale & dirt through the steam holes
Sometimes filling the water tank with lemon juice or running a proprietry steam iron cleaner through it, will resolve this problem. If however, the iron has just had straight tap water all its life, the tank and soleplate may be badly corroded inside... Sorry, but it could be time for a new iron.... If you are lucky, the tank and or soleplate would be available as a spare part but in most cases, if these fail, the iron is considered unrepairable due to the cost and lack of parts..
Aug 04, 2011 | Vacuums
I fill the reservoir before beginning ironing and after I finish ironing there is almost the same amoount of water left in the resevoir. The only time I can spray water is when I press one of the spray...
Hi nananmm,
Try flushing the iron and clearing the holes by filling the iron with a mixture of half white vinegar and half water. Set it for steam and let it sit on an old cloth for about 30 minutes.
This should flush out any buildup in the iron and holes.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 13, 2011 | Vacuums
I need instructions on how to clean Digital Advantage Iron. I have lost my manual.
any iron can be cleaned by running a little water and vinegar through it several times, it loosens the scale build up that gets in all irons over time, be sure and try to clean out the venting steam holes in the face of the iron, Once you do this, run clean clear water through it and you should be fine, if possible, always use bottled water (purified) water in irons
Jun 02, 2011 | Vacuums
I have a stirella dual steam iron. At present it is constantly steaming even though the steam button is not clicked in place. How can I fix this?
It sounds like the steam valve inside the iron is stuck open. You have to take the iron apart and free it up by lightly scraping water deposits off it with a screwdriver.
Mar 16, 2011 | Vacuums
How do i change filter on my Stirella Simac iron
Feb 27, 2011 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
How do you take the casing of a stirella Simac SX4520D steam iron?
It have a torx-plus T20 screw horizontal under the handle.
Sep 26, 2010 | Vacuums
Theres water pouring out of my t fal iron's little holes when I begin to iron my shirt...why!
The iron needs to be cleaned as I have just discovered myself. I have a hinari and the instructions are as follows. Fill the water tank and turn the iron on to medium. When heated press the steam button and hold it over the sink or a container so that the water can run out of it. It will take sediments with it. The cleaning of the iron should be carried out once a month.
I experienced the same trouble and carried out the instructions and all is well again.
Jun 28, 2010 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
