Question about Frigidaire FDL50R1 Dehumidifier
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
  • snyds4 May 17, 2011
    I have never replaced a filter, etc. if that is necessary
    Sergeant:
    Champion:
  • 229 Answers
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
Posted on May 17, 2011
I am not sure of the exact model number, but the unit is rated for 70 pints. It shutdowns and lights the full bucket lamp, but the bucket is not full (there is a hose attached). I dis-assembled the unit...
The problem is that the hose connection tube that the hose is connected to, is clogged. That's the reason water was going to the bucket and the full bucket sensor was shutting the unit OFF
To unclog the tube, you will need an 18" long Plastic Zip Tie or something similar (NO Wire Coat Hangers, though) that is appropriately sized to fit into the hole. Before doing anything, Turn the Master ON/OFF Switch to OFF and unplug the unit.
Carefully insert the Zip Tie into the hose connection hole/tubing and continue to gently push it in, until it reaches the bend in the tubing. You will need to gingerly work past this bend, until it bottoms out or you run out of usable Zip Tie. Now, slowly remove it, while rotating it. This will dislodge the clog. As the Zip Tie is almost totally removed, be prepared for some water to follow.
The above should solve your problem. Will you still need the wiring schematic to reconnect the bucket safety switch? If so, please let me know.
May 28, 2011 | Frigidaire FAD704TDD Dehumidifier
It will not turn on. Is there a reset button? It worked fine for over 5 years, then it just quit.
Hi, Sounds like the circuit board...they often will just do that...IF you can get one it will be half the cost of a new unit...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 19, 2011 | Maytag M7DH65B2A Dehumidifier
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
Auto shut off prevents dehumidifier from working even though there is no water in container.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Dec 02, 2010 | LG Goldstar 30-Pint Dehumidifier
My dehumidifier does not collect any water even though the motor seems to be running
heatman101
Jun 30, 2010 | Goldstar DH304 Dehumidifier
Auto shut off comes on instantly
TURN UNIT OFF.. MAKE SURE DEHUMIDIFIER HAS NOT BEEN RUN FOR AT LEAST FIFTEEN MINUTES... TAKE BUCKET OUT... HOLD IN THE BUTTON THAT THE FLOAT IN THE BUCKET PUSHES ON.. THEN TURN ON THE UNIT.. DO NOT LET GO OF THE BUTTON EVEN A LITTLE BIT IF YOU DO YOU WILL HAVE TO WAIT FIFTEEN MINUTES AND TRY AGAIN.. IF UNIT WORKS THEN YOUR FLOAT IN THE BUCKET IS THE PROBLEM...
May 07, 2010 | Goldstar DH304 Dehumidifier
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Frigidaire FDL50R1 Dehumidifier Logo
813 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
