Question about Grilling
Like its low on gas very weak flame if i turn on another burner its really low
  • 43,501 Answers
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on May 17, 2011
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
Low flame on a 2600 dometic fridge/ flame is not enuff to keep fridge cold
Hi and welcome to FixYa, I am Kelly.
Download this manual:
http://www.dometic.com/9efb3e8b-c980-4383-952c-996a35e3c872.fodoc Go to page 12 for burner cleaning. Clean the burner and the gas orifice (jet) thoroughly. If after cleaning you still have the problem you may have to remove the solenoid vavle and clean out the gas safety valve. The manual also mentions checking LP gas pressure. A weak LP regulator will cause a low flame. I would clean it first... and if you still have a low flame check / replace the LP regulator before tearing into the gas safety valve.
Thanks for choosing FixYa,
Kelly
May 09, 2011 | Dometic RM2620 Refrigerator
A low flame comes out of my burners. I can not make any adjustments to make it hotter.
Unless, your tank not is really low on gas and your burners really don't need cleaning? Try this:
Turn OFF the tank valve and disconnect the hose/regulator assembly from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow), until the tank valve is fully open. Then light the burner farthest from the tank and turn the control knob to the highest setting. Has the flame height returned to normal on that burner? If so, light the remaining burner(s) the same way. Now, do all the burner flame heights look normal? If so, you solved the problem. Just remember to always turn the tank valve on very, very slowly.
If the above didn't solve the problem, turn the tank valve OFF. Disconnect the hose/regulator assembly from the tank and the grill. Then, head on over to your nearest home center or hardware store that sells gas grills and accessories, because you need a new hose/regulator assembly. Be sure to take the old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem.
Apr 29, 2011 | Char-Griller CharGriller Grillin Pro 3001...
Our complex has two Dacor BBQs. Both give off very low heat. It takes 15 mins to get the temp up to 300 and that's as high as it gets. The flame to me look low (weak). Many times the flame cannot make...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
heatman101
Sep 02, 2010 | Dacor Grilling
I have a Thermador SGCS204R cooktop. The rear
Well first you need to verify that it is getting proper gas pressure to that burner. Try lighting the burner manually with a match. Does the burner look normal? If the burner flame is really small then you will need to remove the burner head and check the orfice for a restriction. If it looks normal then it probably is a weak spark from the igniter, igniter electrode is out of position, or burner head has dirty ports at electrode causing no ignition. Inspect the burner head. If it is removable then take it off and clean out the burner ports(eyes) with a sewing needle. If it is not easily removable then try doing this while it is still installed on the range. Also try using a wire brush on the electrode to clean any carbon/debris build-up casuing a weak spark. You can also try bending the electrode slightly with a flatblade screwdriver(be careful don't break the elctrode) away from the burner creating a larger spark.
Jan 16, 2010 | Ovens
Very low flame, like very little gas is getting thru, tank is ful
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
Dec 15, 2009 | Weber Genesis Silver B Grill
My bake burner on my Maytag gas oven is weak, takes forever to pre-heat/cook. Flames are there but low.
Probably need to replace the igniter. Swap the broil and bake igniters and see if the problem follows the igniter. I just had this happen to mine. Glow bar/igniter appeared to be working properly but was weak causing the regulator valve circuit to keep the flames very low. Swapped ingiters as instructed and problem went with the bad igniter to the broil/top burner.
Aug 18, 2009 | Maytag MGS5770 Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Cannot adjust flame on gas burner
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
Nov 20, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Grilling Logo
87 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
