Question about LG Televison & Video
Lg tv remote reset - LG Televison & Video
How do I reset my LG TV remote?
there is no reset on remotes TRY NEW BATTERIES
Oct 06, 2015 | LG 42LG50 42 in. LCD HDTV
Master reset lg led 55
hi try this, press menu on the tv and menu on the remote, if this don't work try ok on the tv and ok on the remote hope it works
regards
shaun
Jan 17, 2014 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
How do I reset my lg plasma tv?
Press the "Menu" button on the remote, then scroll down to the "Picture" setting and press the "Enter" button on the remote. Go to "Screen" and push the "Enter" button, then go to "Reset" and press the "Enter" button again. It will ask you to confirm the reset order. When you do, the image will reset to factory settings.
Read more: LG Plasma TV Troubleshooting ' eHow.com http://www.ehow.com/way_5347793_lg-plasma-tv-troubleshooting.html#ixzz1GjxxXQKI
Hope this helps! -jayps
Mar 16, 2011 | LG Cell Phones
WELL MY 32 INCH LG THE REMOTE LIGHT ON THE VT IS OUT CANT TURN CHANNELS OR ANYTHING FROM THE SIDE BUTTONS OR REMOTE PLEASE HELP
Have you unplugged the LG TV, waited about 2 minutes, and plugged back in to try and reset the TV?
After you reset the TV, try using the key pad on the TV first before you use the LG remote.
May 18, 2010 | LG 32LC7D Television
Is there a way to restore my tv to it's original format?
You need an LG service remote to perform a reset. PN: 105-201M. I believe you use the "In-Stop" button to reset.
Mar 17, 2010 | LG 26LX2R 26 in. HD-Ready LCD TV
Remote tv compatible codes
the default for the rh7823w remote is to operate lg tvs. Popping out the batteries should reset the default. my manual saysto select a different tv hold down the tv power button, press the number buttons for the manufacturer code then release power button.
codes are
LG/Goldstar 1(default), 2
zenith 1,3,4
samsung 6,7
sony 8,9
hitachi 4
good luck
Apr 04, 2009 | Televison & Video
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
Televison & Video Logo
27 people viewed this question
