Question about Technics Audio Players & Recorders
RPM of turntable motor decreases after about an hour of use.Turntable Mo.#SL-BD22-XA :bRAND:Technichs.
  • 1,476 Answers
Crush24,
Your unit is older and probably needs a new belt and a good cleaning and lubrication. You can get the belt here http://1200s.com/Store/p10000368/Technics_SL-BD22_Drive_Belt_Replacement/product_info.html . To replace the belt you will need to remove the platter and while in there you can clean the spindle bearing and motor as well as re-lubricating the motor and spindle shaft. You will need a can of Blue Shower Degreaser, available at http://www.mcmelectronics.com/ as well as lint free wipes and a good oil designed for electronics. To remove the platter you will have to remove a "C" clip on the spindle, below the rubber mat on the surface. Once removed the platter should slide right off the spindle. Using the blue shower spray any turning surfaces as well as both ends of the drive motor. The blue shower will not hurt anything and is the best to remove any grease or dirt. Once all parts are clean and dry apply a small amount of lubricant and reassemble the entire assembly. You will have to remove the rubber mat to access a slot in the platter to hook the belt to the platter using a small flat screwdriver. This should make your unit run as good as new if this was the only problem and the motor did not have more serious issues. Generally after years of use this is the most common problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 17, 2011
How do i find a turntable cartridge technics headshell SL-BD22
The SL-BD22 turntable's tonearm does not have a headshell. It takes a P-mount (otherwise known as a T4P) cartridge which plugs directly into the end of the arm.
May 21, 2014 | Denon DP-47F Turntable
What size belt on the SL-Bd22
Just purchased a belt for my SL-BD22 from Vintage Audo (Audio?). The belt size is 23.6 X .180 X .025 inches. Their part number for this belt is:B00926DJ74. Hope this helps.
Oct 21, 2012 | Technics SL-BD22 Turntable
How do i install a belt on technics turntable sl-bd22
If you remove the rubber pad, you should be able to grasp the metal table. A gentle tap onto the center spindle while pulling up on the table should release the table. Place the new belt onto the underside of the table. Replace the table onto the spindle. Then feed the belt over the motor hub.
Dan
Apr 20, 2011 | Technics SL-BD22 Turntable
The platter on my 15 year old SL-BD22 turntable does not move when I move the tonearm into postion to play a record. Do I need a new motor? If so, where can I find the original equipment, what will it...
Not certain you will need a new motor - yet- !
First since the arm movement turns on the turntable some kind of switch must come into play. These break or move out of poistion, so check that first. The access I suspect will be through the base of the turntable.
As most of these types of turntables use a 12 volt motor, you can attach a 9 volt battery to it's terminals and that should make it spin. If it's dead sluggish or doesnn't spin fast or at all, it's dead. If it does spin then there's something up with the power supply section to it.
Jan 23, 2011 | Technics SL-BD22 Turntable
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
Jan 16, 2010 | Technics SL-BD22 Turntable
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Feb 28, 2009 | Technics SL-BD22 Turntable
32 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
