Stops into wash displays f 10 - Washing Machines
  • 17,970 Answers
F-10 Washing Machine Error Code
Motor control unit (MCU) heat sink failure error code. Thermal sink on MCU overheating.
- Ensure proper clearance around the washing machine.
- Visually inspect motor control board and central control board wire harness connections.
- Test wire harness to motor connection.
Hope this helps.
Posted on May 17, 2011
Daewoo washing machine when turned on does one rotation of drum then displays L _t then displays E1 after 10 secs. Then stops on that.
ie code can mean no water entering machine check water valves and filter or could be solenoid valve in machine faulty
Dec 10, 2016 | Daewoo Washing Machines
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
Wf540hotpoint washing machine runs the programm for about 10 mins then stops. It then displays error code fo3. can you help
i found the hotpoint web site which enabled me to find the error code F03 which tells me that a thermistor created a possible short circuit.
Jul 30, 2008 | Washing Machines
LOC Blinking
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Error display
E10 is a water supply problem first I would check your water lines.. and check the water valves to see if both are open all the way.. next check to see if the screens at the inlets are clear... and last you may need a new water valve in your wather.. let me know if you want to replace it yourself thanks...
Aug 30, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
