Question about Microwave Ovens
Freezer ice build up on bottom of freezer. Refrigerator/freezer both run very cold
  • Ryan Pries May 17, 2011
    Is it sheet ice or frost?
  • Microwave Ovens Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on May 20, 2011
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
Freezer is cold, but ice is forming on the bottom vent and fridge is warm and water droplet on the wall between freezer and fridge
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | Microwave Ovens
Freezer works but frig not cooling
if you were to reach your hand towards the rear inside the fridge area can you feel cold air blowing into the refrigerator side if not this could either be due to the fan inside the freezer area not working or there is a small door that is controled by a thermostat inside the ceiling of your refrigerator this thermostat when it reaches a tempreture that is to warm it opens a small door in the rear that connects to the freezer allowing cold air to come into the refrigerator side when the refrigerator becomes cold enough the thermostat then shuts the door. You could also have a defrost issue inside the freezer area in which u would need to remove the rear panel in the rear of the freezer in order to assure you did not have this issue. If you remove the rear panel and you see any ice build up on the evaporator coil (note this is also where the fan that blows the cold air into your refrigerator is located)you would have a defrost issue. If you remove that rear panel and find any ice build up message me back and il instruct how to fix but first check to assure you have air blowing into the refrigerator side. If you dont then you have to diagnose which is causing the issue either the fan which you could hear if you listened inside of the freezer area or the door itself is not opening due to a malfunction with the thermostat if you have any further questions message me back and please also remember when our chat has fully conlcuded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks
Rick
Jun 24, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Ice maker not working and freezer not cold enough, food is not frozen solid, but ice we put in tray does not melt completelyu
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 05, 2011 | Microwave Ovens
Water is leaking down through what i am calling the vent in the top of the fridge inside and it is building up over a few weeks and then it runs out on the floor.
I have experienced this very same problem before. There is a small condensate drain hole in the rear of the freezer compartment on some model refrigerators. If it ices over, the condensate has no where to go but down through the louvers and into the refrigerator compartment. It usually drips from the center overhead area down on to the shelves and accumulates in the bottom until it runs out the bottom of the door.. One way to tell is to check the back of the refrigerator to see if there is a visible drain line (larger in diameter than the ice make water line) that runs from the freezer compartment down to the compressor area. You may want remove everything and defrost the freezer and see if the problem goes away.
If you have questions/concerns, please post back with your MODEL NUMBER and let me know. I hope this helps you.
NOTE: Even if this is a frostless refrigerator, I have experienced the problem where ice can build up and plug the drain. You may have to remove the bottom tray in the freezer to access it.
Aug 27, 2010 | Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
