Question about Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine
Ice machine will not work. bin full light will not go out! Please help!
  • 23 Answers
There are lens on the bin that shoot a beam across if there is ice it stops the beam and tells it's full. It can also become covered with calcuim and also tells the bin it is full. I would clean these lens gently with a cacium remover. they make products for this. its like an acid that clean off the calcium without damaging your lens.
Posted on Oct 08, 2011
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: where are the bin full sensors located for
It is a set of eyes located in the very back right and left hand side where the ice drops into the bin. Take some ice machine cleaner and wipe down the eyes. You should be able to pull the holders out to get to them better.
Posted on Feb 09, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
  • 4 Answers
SOURCE: scotsman ice machine CME 1056RS\r\nThe bin full
change the board and eyes at the same time.
Posted on Nov 29, 2010
Bin light on no ice water running bin warm
Check the ice-full probe if bad replace this is what tells machine that the ice bin is full. the bin is not refrigerated just a storage bin.
Jan 20, 2014 | Franklin Industries Franklin Chef Ice Cube...
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Where are the bin full sensors located for cme306as-1c bin full light on will not make ice.
Jan 30, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My binsensor lingh is on but my bin is not full so my ice machine
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Apr 23, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
Bin control
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Dec 27, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Refrigerators Logo
450 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
