Error code 0xe0ef000"
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
I can't update samsung apps as it gives me an error: "Service not available(Error code: 2000)"
you all are incompetint of answering the simplest question. honestly all of the responses you have provided are completely absured. WOW. fanboys. GGK.
Mar 31, 2012 | Samsung Galaxy S I9000 (8 GB) Cell Phone
Error Code 28
Hello
Unplug the AC power chord for about 10 minutes, and then replug it and see whether it helps you.
Confirm the current software version.
If the software version is updated, if the software update has succeeded. If not, try again.
Do not unplug the unit frm AC while the software is udating. All settings will remain the same even if you updated the sofrware with newst version.
Nov 13, 2011 | Televison & Video
Whenever i try to open autocad i get this error "unable to initialize adlm" the body of the error goes like this "preptool has not been run since build" "error code 6"
It sounds like there was an issue with the install. My suggestion would be to completely uninstall it then reinstall it.
Aug 29, 2011 | Computers & Internet
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
The orange "Alarm" light keeps
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. According to the service manual you will need to replace the sheet feed unit, logic board assy, purge unit.
Feb 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My Mitsubishi WD-73734 TV will intermittently just shut down- no picture, no sound, the set just turns off. When I check the TV for an "error code," I am able to identify error code # 38. What...
38 Lamp temperature abnormally high. Poor Air Circulation - found in service guide at - http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf
Dec 17, 2010 | Mitsubishi WD-73734 73" Television
Computers & Internet Logo
148 people viewed this question
David Payne
David Payne
