Question about AT&T 650530003417 Cordless Phone
At&t TL32100 cordless phone has flashing ans on light and flashing in use light. Phone does not work and only shows battery charging icon.
  • Kath Dec 17, 2011
    I am having the same issue. Did you ever find a solution?
5 Suggested Answers
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
  • 5 Answers
SOURCE: Vtech 2656 cordless phone battery not charging
These phones seem to have this problem, I'm not sure a new battery will fix it. I have found a wierd fix that works for me, but I have no clue why.
1-take the battery out,
2-leave it out about 30 seconds,
3-then put it back in but leave the cover off,
4-place it back in the cradle however you can with the battery hanging out (I wrap it around),
Now it will charge much more thoroughly for some reason???
Posted on Apr 16, 2009
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
SOURCE: KX-TG6051B panasonic cordless phone - lcd screen doesn't work
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Posted on Oct 23, 2010
Panasonic cordless phone rings, but when you answer the phone goes dead
Check the charging contacts make sure it is charging when in the cradle. If problem is remove the battery and let it stand for one minute than re-plug battery in unit place briefly in cradle, until display and or charge indicator lights up . Try making a call . IF ALL ELSE FAILS RUN TO TOP OF HIGH RISE BUILDING THROW HANDSET TOWARD EMPTY PARKING LOT !! BUY a BETTER QUALITY PHONE S#&@T HAPPENS
Sep 01, 2012 | Panasonic KX-TG1100 Cordless Phone
Getting msg 'PILE FAIBLE' on my GN7170 Cordless phone. What does it mean?
Pile Faible is french for 'low battery'. This indicates that either your base station is not charging the phone or the rechergeable batteries need replacing. Is there an indicator light on the base station that shows charging is taking place? If that does not light when you replace the phone on the base try cleaning the contacts on the phone and the base with spirit (methylated spirit or other pure alcohol - vodka will work!)
Jan 04, 2011 | GN Netcom GN-7170 Cordless Phone (GN7170)
When charging the phone, the battery icon flashes off and on and the phone make a sound is it charging properly
hello,
it is not supposed to make any sound when charging, if it does it means there is a problem somewhere.
it is not charging properly. try to turn off the phone and plug the charger. its supposed to bring up a light the show the battery meter and show it charging bar by bar, if it doesn't come up this way, try using the same charger on another phone to see if the charger is working. anything you detect, try to replace the battery and try again.
Jan 27, 2010 | Motorola Mobility W377 Met Silver/Pink...
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
Phone not working, icon which indicates range flashing
found the user guide online. check page 18. there is a chart there that shows your problem and solution!
Jan 09, 2009 | Panasonic KX-TG1100 Cordless Phone
I just bought a new Vtech cordless phone, 5.8GHz, model CS5111, hooked up the new battery and the base and have been charging it now for Twenty-Two (22) hours and the red charge light is still on!!! The...
The red "charge" light comes on to indicate that the handset is inserted properly into the base. This is it's normal function. No further action is nessesary. :)
Nov 23, 2008 | Cell Phones
4900 phone problems
Probably need new battery, you can get one here - IBM 4900 Cordless battery
Oct 02, 2007 | IBM 4900 4-Line Cordless Phone
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
AT&T 650530003417 Cordless Phone Logo
389 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
