Question about Keurig Platinum B70 Coffee Maker
When the brewing sign come on the water is comming out where the water container is fron the top hose. after about a minute it goes back to ready to brew. Can you help
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
My Coffee maker is not brewing, and the screen says de-scale. I don't know what to do, I remove the water container, turned it off and back on. I will appreciate your help, thanks Andrea
Step 1: Plug Brewer in and turn power "ON".
Step 2: Pour approximately 64 oz of the vinegar into the Brewer until 4 beeps signal the tank is full.
Step 3: Wait about 6 - 8 minutes for the vinegar to heat up and the green "READY" light to go on.
Step 4: Place a ceramic mug in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP...just press the Brew button.
Step 5: Repeat the brew process 4 or 5 times pouring the contents of the mug back into the Brewer after each cycle.
Step 6: Now let the Brewer stand for 4 hours while still on.
Step 7: Place a ceramic mug on the Drip Tray and run 4 brew cycles, pouring the contents of the mug into the sink after each cycle.
Step 8: Turn the brewer off, let the remaining vinegar cool, and drain the brewer as instructed above.
CAUTION: Vinegar may still be hot. Remember to replace the Drain Cap.
c. RINSE
Step 1: Fill the brewer with hot tap water.
Step 2: Power up brewer.
Step 3: Wait about 6-8 minutes for the water to heat up and the Green "Ready" Light to go on.
Step 4: Place a ceramic mug on the Drip Tray and run a brew cycle.
Step 5: Repeat brew process 4 times for a total of 5 cycles.
Step 6: Drain the brewer as instructed above.
CAUTION: Water may be hot. Remember to replace the Drain Cap.
Step 7: You may need to rinse again to eliminate any residual taste.
http://www.keurig.com/Customer-Service/Brewer-Registration-And-Support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions_04_30_2004.ashx
Jun 06, 2011 | Keurig Platinum B70 Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
TB3 Brewer is brewing weak tea - how do I adjust?
Hello. Yes, however, you would need to adjust the brewing cycle time to make up for the lost bypass water in order to get the same container level. In other words, the cold water part of the brew cycle is separate from the hot water part of the cycle, if you put in less cold water, and want to keep you container filling to its current level, you would need to increase the hot part of the brew cycle to make up for it, other wise it will brew less into your normal container. If you go to:
http://www.bunnomatic.com/
find your unit by model/type, you should be able to get a owners/installation manual, this will tell how to do it, or call the manufacture.
Hope that helps, and thank you.
Dec 22, 2008 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Apr 05, 2008 | Bunn NHB Coffee Maker
Does not brew a full pot of coffee
1) Unplug the NHB
27) Empty pot.
Oct 29, 2007 | Bunn NHB Coffee Maker
Tassimo
Mine sometimes does this but cleaning the barcode reader at the top of the machine (small glass panel) fixed it. Also make sure the water container is seated correctly. If these dont fix it try pushing the water container left right/back front while there is a disc in the machine-mine has started to only work if I push the fitted water container backwards when "brewing".Its out of warranty now so I will make do until it breaks completely. Regards Nicki
May 09, 2007 | Braun Tassimo Espresso Machine/Coffee...
Keurig Platinum B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
