Question about Logitech S150 2 Speakers
I have a set of Logitech speakers s150 USB and Ive had them for about over a year and about a few days ago they were working fine...but now they just won turn on. usually i just unplug them and replug them and they turn on now but thats not the case this time... now they wont turn on at all. Ive tried restarting the comp, looking for new drivers(usually saids i have everything up to date), Ive tried plugging it into other ports but still wont work( i checked to see if it was the ports themselves but thats not case either Ive tested them out with other devices) so some assistance would be appreciated
  • Logitech Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
also try this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or
hope this helps
Posted on May 17, 2011
Do s-150 usb digital speakers work for mac?
Hi, I had this problem too but thankfully I figured it out after a investigating a few settings. I was very frustrated because the light came on and the buttons would manipulate my MacBook Pro and MacBook sound, but nothing came out of the speakers. Solution:1.) Click on System Preferences, 2.) Choose "Sound", 3.) Select the "Output" button in the middle of the top bar, 4.) in the selectable menu, choose USB (of course your speakers must be plugged in for this to show). Tada! You can even balance the Left and Right speakers in this menu. Hope that works for you too!
Jul 29, 2012 | Logitech S150 2 Speakers
S150 speakers sound scratchy
If you have just purchased these speakers, it is likely a loose piece inside, or the plastic buttons on front vibrating loudly when sound is played.
Quick fix:
Place a piece of tape over the buttons on the front.
Longer fix:
1. Remove both phillips head screws from the back.
2. Remove speaker guard. It is held on with 3 pressure pins. With a small flat head screwdriver, You can get underneath the guard and apply force. The trick, is to focus your net force perpendicular to the face of the speaker. You don't have to be too gentle, but be wary of flexing the plastic guard too much or it may break.
3. Remove both phillips head screws from the front.
4. Open speaker unit and remove two small screws from circuit board.
5. Cut two pieces of soft tissue paper big enough to fill the button housing underneath the circuit board. (The thinking here, is that the tissue will dampen any rattling from the buttons. Don't worry! The buttons will still work).
6. Re-assemble the speaker, taking care to tighten all screws.
Mar 24, 2012 | Logitech S150 2 Speakers
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall
then restart your computer and reinstall your soundcard
hope this helps
Nov 21, 2011 | Logitech X-540 Computer Speakers
I got a set of Logitech S-150 USB digital speakers for Christmas, and the very first time I plugged them in (and every time since) they have been very unbalanced. The right speaker seems to be fine and can...
Logitech are usually good speakers, I have had them for a long time and would suggest that there is a problem with the speaker in question. My advice would be to return them for a replacement
Dec 29, 2010 | Logitech S150 2 Speakers
Hi, I have a logitech lapdesk with speakers. From last few days when I plug it in to USB of my laptop. My laptop use logitech speakers however control for the volume or mute still remains with laptop.2...
Hi nidkap,
My name is Oliver Riemann and I work in the product marketing group for Laptop Accessories. I was disappointed to learn about your recent experiences with the Speaker Lapdesk - this experience is not what we would wish for our customers.
The issue you describe in your mail could have various causes, and our engineers are willing to investigate in order to be able to deliver the best experience.
But we want to help you now. I would be happy to exchange your lapdesk with a totally new one. If this offers suits you, please feel free to contact me via email.
Thank you,
Oliver
Oliver_Riemann@logitech.com
Oct 02, 2010 | Logitech N700
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
Logitec250headset mic not working at all on this pc
Hi, Please uninstall any logitech software version present on your OS - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Aug 25, 2009 | Logitech 250 Headset
Sound mostly out of one speaker
my spearker will not work it saids audio default
Dec 06, 2008 | Logitech X-530 Computer Speakers
Logitech cam
Did you install the driver cd. Check its working properly.
Feb 22, 2008 | Logitech QuickCam Chat Personal Web Camera
Logitech S150 2 Speakers Logo
198 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
