Question about Dryers
Information code "E3" appears on
  • 2 more comments
  • klkroma May 22, 2011
    Oops, sorry about that! The dryer actually started working again once I rescued a shirt that had gotten twisted up and caught in a part near the door to the Samsung DV665J. I would still like to know what E3 means, though.
    Thank you--
    Katherine
  • klkroma May 23, 2011
    So the thermostat might need replacing? Would a bad thermostat mean drying might take hours, which it does? I was told that the dryer taking a long time meant that the connecting hose to the outside was full of lint or otherwise blocked. (The guy who has been going to take a look at this hasn't shown up when he said he would).
    Thank you, Kevin!
  • klkroma May 24, 2011
    OK! I guess I know where to go from here...thanks very much, Kevin...
    Kevin was helpful and gave me good advice about what to do with my dryer.
  • Dryers Master
  • 1,902 Answers
Hello & Welcome to FixYa
Please get back with the make and model# of your dryer so that I can tell you what this error code means and how to fix it.
Kevin
Posted on May 17, 2011
  • 1 more comment
  • Kevin White
    Kevin White May 22, 2011
    Yeah...E3 error
    is a overload error and flashes when either the vent is blocked or the thermal
    fuse/thermostat is bad and needs replaced. Great that its solved for you......Please
    get back to me if you have any other questions.
    Kevin
    Yeah...E3 error is a overload error and flashes when either the vent is blocked or the thermal fuse/thermostat is bad and needs replaced. Great that its solved for you......Please get back to me if you have any other questions.
    Kevin
  • Kevin White
    Kevin White May 23, 2011
    You are correct Katherine....the thermostat needs replacement
  • Kevin White
    Kevin White May 24, 2011
    You are welcome :) Thanks for that rating
I have a Blyss WDH316DC dehumidifier with E3 in display. What does this mean?
What E3 Means? This is simply an error code with your dehumidifier please.
It s not clear whether you can attempt to reset your unit or fix it on yoir own. So sorry about this.
It appears yoir unit requires repair by a qualified dehumidifier service technician.
You can exploit the warranty if this is still valid. Simply return to point of purchase with your original receipt
Nov 13, 2017 | Dehumidifiers
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
My whirlpool cabrio dryer has an error code "PF" What does this mean?
The PF error code means power failure. IF the dryer was running and the power went off that display would show. I am assuming your power didtn go off yet the dryer trought it did, so the things to check is for a good tight connection on the power cord at the back of the dryer, a possible loose connection on the wall outlet where the cord plugs into ,or even a weak circuit breaker.
Good luck,
Gene
Aug 13, 2011 | Dryers
It won't start and displays E3 fault code. Manual says this is faulty coils? Took apart and cleaned all, looks good. Still has code displayed and won't run. How to clear fault code? Thank You.Jeff
E3 means "unit-abnormal protection to avoid occurence of unit damage."
Manufactures does not recommend that a homeowner try to attempt a repair on a code like this as it indicates possible wiring or internal problems. Have you checked for an internal fuse on the circuit board? I would also check the incoming power to make sure you have the proper voltage. You can also try unplugging the unit, waiting 30 seconds and plug back in to see if the code disappears.
According to A/A brands, if this code appears, shut off device and call authorized service company. I'm just trying to get you some things you can check yourself prior to doing that.
Hope this helps.
Jul 29, 2011 | Home Pride AA-TH 358 Air Conditioner
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
I have a maytag DC68-02031A clothes dryer. When I
E 3 is not a maytag fault code . may be f 3 . I need your model & ser # and I can tell you more . thams mm
Nov 20, 2009 | Refrigerators
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
Kenwood washing machine display showing E3
e3 means there was a longer heating time but not reaching required temperature could be a malfunction of temperature sensor or of heating element.
Please do rate my solution also do post further comments if any help needed.Good luck with the machine.
Apr 08, 2009 | Washing Machines
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Kenwood dishwasher kdw243a
kdw243a code E3 what doesthis mean. ??? pleae.. adres Poland,,,,,, e_mail wiesiekwro@poczta.fm
Dec 14, 2007 | Kenmore Dishwashers
Dryers Logo
170 people viewed this question
Top Dryers Experts
