Question about Sharp Notevision PG-B10S Multimedia Projector
Progressively worse red "ghosting" when showing films....
A strange problem:
* When playing a DVD start to get a red line around the outside of lines on images in the black areas (eg the edge of peoples faces, bodies etc)
* The red lining gets worse during the film, getting thicker and appearing more
* "Tapping" the top of the projector tended to make the problem go away for a time, but then it returned....however, once it became worse (thicker red lines, more red), then no amount of tapping could rectify.
* This problem has occurred before, but seemed to go away (when playing a film some days later). However now it is back again. We often do public screenings so can't afford to be unsure if the projector will come through or not....
* The lamp says it has 85% left, so should be fine. After getting worse, the red "ghosting" appears even on the start up screen (ie it seems not to be related to the connection or a particular film).
....Please help - thanks
  • 4,234 Answers
This could be either a connection problem internally or a problem with the red filter convergence. This is not a project to be attempted by an inexperienced person. The convergence adjustments should only be attempted with the proper setup and equipment. If you can solder, carefully open up the unit and look for poor solder joints and resolder them. You can also reseat all of the connectors and cables. If neither of the above ersolve the problem, take it in for service.
Dan
Posted on Aug 14, 2008
Hello. I am on a laptop right now, but my gateway desktop is acting weird. I was playing Rome Total War, when my screen started having strange colors and the computer shut down. Everytime I boot the...
you may got infected...first run scan on the system and then reboot and see if you normally use it then try going to play again if that happen again then you need to get new video card
Nov 07, 2009 | Office Equipment & Supplies
Lines in 42" plasma tv when it warms up
it prob over heated and burnt one of the components in the tv you need to keep the room at a good temp same with all electronics so they dont over heat and mess up thats just one thing i think it could be
Aug 11, 2009 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Floating lines in picture
"Floating lines" usually caused by bad cable signal. Try playing a dvd or tape. If lines are gone, tighten all cable connections. If lines are there, you could need convergence repair if any colored shadows or ghosts are visable around on screen lettering. Hope it's some help anyway.
May 29, 2008 | Televison & Video
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Plays MP3 files at high speed
Try newest firmware. It should work for all Onkyo DVD-players:
http://gamerlamers.com/Onkyo_DV-SP1000_firmware_update/
Regards
Svein
Oct 31, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Sharp Notevision PG-B10S Multimedia Projector Logo
181 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
