Question about Fantech (ser2004n) Air Purifier
Of the pannel on a Fantech SHR 2005What is the function of the "current switch". When is it activated? What are the "COM" and "IN" terminals connected to? i.e. do you short the COM to IN to turn off or do you connect a "" to IN to turn off.
  • 1 more comment
  • ab438 May 18, 2011
    The suggested schematic shows only the external details ( I have that manual. It came with the unit and is freely available on the web.) The described switch sets the low ("standby") speed to Low, Off, Medium. The same manual shows the Dehumidistat, On/Off unit(MDEH2) connected with 4 wires; two to the DEHUM terminals. When these terminals are shorted the unit is forced into high speed mode. The other two wires are connected to the CUR SW terminals. Since only one On/off controller can be connected, I presume (but do not know - hence my question) if shorting the +, COM terminals is supposed to stop the unit. This could likely be determined if I had the schematic for the control unit
  • ab438 May 19, 2011
    My question is how to turn the unit off remotely.
    The humidistat forces it into HI when on demand,. When the humidistat is satisfied or the DEHUMID terminals are open, It switches into LOW (or such as the standby switch is set). It appeared from the manual that connections to the current switch turn the unit off. This could be by shorting or applying a voltage from the HUMID terminals. If the latter wers the case, there would need be only three wires unless the fourth goes to a pilot.
    In the manual, note the descriptions on page 15 (re MDEH2) and page 16 (showing the connection of MDEH2)
  • Anonymous Mar 17, 2014
    We bought a house with a Fantech HRV unit. It has a 2 wire Honeywell dehumidistat control on thee wall. What do we set it at if hour house is too dry?
  • 1,940 Answers
Every time the unit is plugged in, it will go through a 45 second self diagnostic. During this time, the fresh air fans will not turn on.
The switch on the side of the unit is used to toggle between STANDBY, LOW speed and MEDIUM speed modes. In order to activate HIGH speed, a jumper must be placed between the DEHUM + and DEHUM - contacts.
The Current Switch/IN COM is wired to a Dehumidistat On/Off with 4 wires, or to the Fantech RTS3 Intermittent Timer. I don't believe you short the COM to IN, but to make sure, check the following wiring diagram.
For a wiring diagram, please refer to pages 16 and 17 of the following installation guide:
http://fantech.net/docs-resi/401347-shr-vhr-install.pdf
Posted on May 20, 2011
  • Fantech Master
  • 43,501 Answers
The main switch's function is to set the unit for off, intermittent mode or continuous mode.
If you hook a dehumidistat or timer to the Com and in and then set it to intermittent then the unit will run when they are calling for it to run...
If you set the switch for constant it will always run...
There are also defrost modes for cold weather climates...
Here is the manual which explains everything and has wiring diagrams towards the back... about page 26
SHR2005 manual
heatman101
Posted on May 17, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 18, 2011
    I think that you are over thinking this and I am not following exactly what it is that you are trying to do with the unit.
    The only way you can hope to get a schematic of the control it's self is to call the factory directly and ask for their tech. support people and talk to them directly.
    I have wired many of these units and have always just set them up like you siad to run on low constant and then kick up to high if the humidity levels get too high. That is normally how I hook them up and they work great.
    heatman101
  • D. Floyd Kolb
    D. Floyd Kolb May 19, 2011
    Ok... now I got ya....
    Yes, shorting the "in" and the "com" terminals should turn the unit off... unless there is a factory jumper across those terminals...in that case then opening or taking the jumper off will turn the unit off....
    But yes that dehimd. 2 stat is a 4 wire deal and you will need two wires for the dehumid part and 2 for the on/off part...
    heatman101
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
Where does (light green) ground wire attach to, came loose mhen I opened top thank you
We will need to know the make and modek in order to help you.
Apr 25, 2015 | Air Purifiers
Machine doesnt turn on. Is there a reset
Check the screen to make sure the plastic piece is depressing the switch at the bottom...the machine will not activate to on if this switch is not on..and depressed by the plastic piece on the Flair SCREEN.
Apr 29, 2012 | Ecoquest Flair Air Purifier
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
Doesn't work and I've checked all the connections and I've cleaned it thoroughly
By checking all the connections, do you mean you've looked at each component to make sure the machine is assembled so as to activate all of the safety features?
1) The back screen needs to be inserted so that the tab depresses the interior safety switch in the slot. You'll be able to hear it click. Wiggle the screen if the little tab seems loose. Some need to be inserted down on top of the switch, others need to push the switch back. Try both ways.
2) Have you checked the fuse? If it is blown, replace it with the EXACT same size, available from an auto parts store.
3) Is the wall socket live? (I know, that sounds totally stupid! But you'd be surprised at how often the wall socket is dead! (Often turned off by a switch somewhere else.)
4) If there's a switch on the far right side (some have this feature, some don't), set it to "Manual" and leave it there. The "auto" feature sometimes is deactivated or stops working.
5) Make sure the switch on the front is "On."
6) Try turning the knobs to different settings. Sometimes the lower settings are too low to activate the machine.
Hope this helps. If none of these troubleshooting steps helps, you can call Vollara (new name for Alpine/EcoQuest) and they'll give you some great options. 800-989-2299. Use #16618 if they ask for a referral number.
Jan 22, 2011 | Alpine Air XL-15 Air Purifier
I have an Eagle 5000 air purifier. Stopped working
Just went thru this Tues. Get the top of screen in place and then push the plastic in on safety switch. I was having it push down and then slide screen in. That plastic piece is split like when you push it in, it hits 2 different heights. Instead of pushing it down get top in and push the plastic in, easy. Turned on then. Already had the switch on so it fired up soon as I pushed it in.
Jan 15, 2010 | Eagle Advantage Alpine Air Purifiers Eagle...
Plug it in and the light goes on but it does not operate
Check the lint screen on the back of the machine and ensure that the safety switch activator clip depresses the safety switch.
Nov 15, 2009 | Ecoquest Breeze AT Living Air Purifier
Xl-115 Automatic setting not working?
your sensor board has failed , a realy common problem , most if not all are dead and no parts are made for it ...... you do not need the sensor anyway it was only installed as a knee **** reaction to fda worrys of ozone levels over 0.05 ppm in bedrooms . so the board was installed to cut at 0.05 ...... it was a failure , so a bypass switch was added to get around the problem board ... just set on man , adjust for your sq ft ... you will be fine
Sep 08, 2009 | Ecoquest Living Air Classic Air Purifier
I need a wiring guide for the Hunter Hepatech 30057. The switch wires have come apart. Thanks.
i normally dont help people in this matter , but I can understand your problem . go to www.ytb.com/gizelle & click on "view company presentation ". This should help !
May 01, 2009 | Air Purifiers
Fantech (ser2004n) Air Purifier Logo
110 people viewed this question
Top Fantech Air Purifiers Experts
Are you a Fantech Air Purifier Expert? Answer questions, earn points and help others
