Question about Sanyo DP42746 42 in. Plasma Television
After power outage our Sanyo model #DP50719 will turn on for 5 seconds and then turn off and keeps doing this until i have to turn it off with the remote. When it turns on there is no picture, it seems to power down when the picture is suppose to come on to the screen.
shivam4529
  • 150 Answers
SOURCE: sanyo vizon tv black screen
hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
Posted on May 24, 2008
waynejamescm
  • 67 Answers
SOURCE: Sanyo DP32746 screen black no sound screen flashes when turned on
Hello, I just posted this to another user's question, and you might find it useful, too.
I have a pile of these in my shop. Unfortunately and usually, a backlight lamp is bad, and the inverter board is damaged when it goes out. The backlight lamps are sealed inside the panel, so the usual method of repair is to replace the panel.
If you turn the lights off in the room, then turn the tv on, you will probably see a momentary flash of light from the backlight trying to start up. The lamps can be replaced, but the option is not really cost effective given the amount of time it takes to replace them/very delicate nature of the lamps/availability of the lamps/cost of the lamps. Replacement panels might be available, but you'd have to use a TV shop for reference or call Sanyo directly.
These units also have a history of power supply heat damage, so if you don't see the momentary flash, it could be the power supply. But the momentary flash is the dead giveaway.
I hope this helps you...
Posted on Dec 30, 2008
  • 135 Answers
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Posted on Aug 23, 2009
budmrtn
  • 11361 Answers
SOURCE: 37' lcd sanyo. sound no picture. no backlight.
Check the lamps connectors on the backlight inverter board make sure they are not loose. You may be ahving failing inverter board itself.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 22, 2010
  • 132 Answers
SOURCE: My sanyo dp42840 flat screen
The first thing I would check would be the electrolytic capacitors on the power supply board. If any of them are swollen or domed on top rather than flat, they will need to be replaced and that will fix your problem. I fix about 75% of them at the shop by replacing caps on power supply. A tech will probably charge around $100 if it is bad caps. It is a fairly easy job.
Posted on Jul 31, 2010
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
Feb 01, 2015 | Samsung 26.0 cu. ft. French-Door Bottom...
Picture on a Sanyo dp42848
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
Sep 08, 2014 | Sanyo DP26648A DP32648 DP37649 DP42848...
Sanyo dp50719
Finding a used screen is looking for a needle in a hay stack. You will have better luck looking on Craig's list for the same model that isn't working. Replacement screens can be had...just google them and you'll be able to find one. Price may shock you and with shipping and installation costs it may be more than a new tv.
Dec 28, 2013 | Televison & Video
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
I have no screen or sound the power light stays on for 5 seconds then goes out again
Get the TV model number and chassis version from the back panel and try
http://www.coppelltvrepair.com/Diagnose/
I wish I could be more helpful, but without those two pieces there's really nothing more I could do.
Mar 26, 2013 | Sanyo 42 in. LCD TV
Need to remove close caption from sony dp50719 but I do not have a remote control
you should be able to access an navigate the menus using the channel and volume buttons on the TV. Here's a link to the user manual if it helps:
http://us.sanyo.com/dynamic/product/Downloads/DP50719%20manual%20337-48985803.pdf
you can also purchase a new remote for $24.99 here
http://us.sanyo.com/SANYO-Store/Model-Specific-TV-Remotes
Sep 14, 2010 | Sanyo Televison & Video
Need a code for
turn device on
- press and hold code search button until red light blinks
- press the device button you wish to program
- press the power button and release. Do this repeatedly (pausing 1 second in between) until device shuts off.
- press and hold enter button for 5 seconds.
May 12, 2008 | Televison & Video
I need a manual with the progamming codes for a Sanyo tv
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Dec 22, 2007 | RCA RCR660 Remote Control
Sanyo DP42746 42 in. Plasma Television Logo
227 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
