Question about Kodak EasyShare CX7430 Digital Camera
My camera says that the internal memory is full, but i have a sim card installed. how do i get it to switch over?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Press MENU to access the settings menu. Use cursor-up/down to select "Image Storage" and switch it to "Auto".
Posted on May 17, 2011
Benimur
  • 6966 Answers
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
  • 4090 Answers
SOURCE: Internal Memory Full??
The Internal memory and SD card are different beasts. There is a certain value that alows pics to be taken without a memory card in situe. It is this part that is saying the memory is full Use settings to clear internal meory of photos or files being held. If this oersists even after yoiu have emptied the memory you will need to take it to a Kodak outlet
Posted on Jul 27, 2009
  • 11967 Answers
SOURCE: internal memory full-
There should be a way to do that in the setup menu.
Posted on Aug 12, 2009
  • 11967 Answers
SOURCE: How do I switch between internal memory and memory card?
When you remove the card, can you review the pictures that are on the internal memory? If you can and you want to save them, download them to your computer. Then, with the memory card still out of the camera, format the internal memory.
Posted on Oct 27, 2009
i have this same problem i even tried formatting my memory card and my camera and it still wont recognize the card i inserted
Posted on Feb 22, 2010
Ge X550 will not switch to memory card when it is installed, stays on internal memory
Hi, a few possibilities...you may have a menu setting that only saves to internal memory, so: clear your custom menus and check your shooting and playback settings. The specs on your camera states that it supports up to 16GB card, so the problem should be a menu setting. Also make sure the little tab on the left side of the SD card is NOT in the lock position.
May 08, 2014 | GE X550-WH Power PRO Series Digital Camera...
Internal memory card full
Hello, You need to either download the images to your PC or delete the images from the internal memory or you need to install a blank memory card in the slot and save images to that card.
Best Regards, Russell
Dec 17, 2012 | Kodak EasyShare C613 Digital Camera
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
Apr 28, 2011 | Kodak EasyShare One Digital Camera
I am getting a blank screen and a message that says internal memory full. But I took all the photos off the camera and downloaded them to my computer.
OK, you can switch to your memory card's memory if you have one installed. The Internal memory is sparse and small compared to say a 2 gigabyte memory card.
Also, delete the internal memory pictures if you're set on using that type of memory.
Jul 09, 2010 | Kodak EasyShare One Digital Camera
Fuji 45fd -- internal memory full. How do I
It should read the card as soon as you insert it.
Mar 26, 2010 | Kodak EasyShare C613 Digital Camera
Oct 27, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Can't switch from internal to memory card
Download the internal memory pictures to your computer, then format the internal memory. Then go into the camera menu to "reset" and follow the on-screen instructions.
Sep 08, 2009 | Kodak EasyShare One Digital Camera
Switching from internal memory to memory card
Push the MENU button and advance through the options until IMAGE STORAGE comes up. Setting this for AUTO will route all new pics to the memory card, using internal memory only if the card is full.
Aug 23, 2009 | Kodak EasyShare Z612 Digital Camera
Internal memory full ??
In the settings switch from internal mem. to the card
Mar 25, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare CX7430 Digital Camera Logo
121 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
