I have a panasonic 42inch plasma, problem is it only pics up 2 stations i even have a converter box ive tried to set and re-set but nothing works what can i do?
    Scholar:
  • 74 Answers
You may need to use a larger or different type of antenna. The website listed below will suggest the proper style and size antenna for your location.
Click Here to begin
Then click CHOOSE ANTENNA.
Posted on May 17, 2011
Have Panasonic The;37pw5 plasma tv . How do I get broadcast tv?
You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
The specifications for the TH-37PW5 are available on page 38 of the manual. This is available from Panasonic here: ftp://ftp.panasonic.com/television/om/th-42pw5_en_om.pdf .
I hope this helps.
Dec 14, 2016 | Panasonic Televison & Video
How do i fix an 08 panasonic plasma tv,it will work perfect for a few hours but then goes back to green highlights,i have pics. I
It sounds like it's overheating. If you can put a small electric fan behind it and see if that fixes the problem.
My plasma has a regular box fan behind it to cool it off.
Nov 10, 2014 | Televison & Video
Sansui 42inch snows after a while of watching!
Nothing wrong with motherboard engine it seems looking like issue with plasma display connector top left and right side , if you good on that to do it yourself then have look pic or send me pics inside http://electronicdoctor.weebly.com Connection may be different on your TV set 4_4_2014_12_20_43_pm.png
Feb 05, 2014 | Televison & Video
I am trying to set my toshiba ct-90159 to connect to a converter box, however, I need to change to channel 60 and i can't figure out how to do that. I have a dish satellite with 2 cable hookups and my tv...
You should be able to just connect the satellite box A/V output to the A/V inputs on the tv without the converter box. Most converter boxs are set up for the tv to be on channel 3/4. Just input the number 3/4 or whatever into the remote of the tv and press enter.
Sep 01, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
New 42inch plasma turned off while watching, can't turn on
Panasonic requires an authorization number first from them. Our parts suppliers require that before we can even order the part. I recommend calling a svc co. to have it looked at, preferably an authorized panasonic service center, it will be much faster.
May 31, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Hi all i have a samsung 42inch plasma and i have sound , no pic ?
Your info doesn't indicate if you have a good onscreen display or not. If you do the problem is highly likely to be on the IO board on the rear patch panel of the tv. Replace this board and it should take care of the problem.
If you don't have a good on screen display the two common problems are either on the power supply module or the digital control module. Samsung is known to have problems on both these modules and an electronics technician should be able to remove these modules to inspect for cracked solder joints, or out of tolerance electrolytic filters.
If these conditions do not exist on either board then the power supply board should be replaced first before replacing the digital control board. Search for a vendor that will offer you a full refund will a small restocking fee if the board does not take care of the problem.
Apr 28, 2009 | Televison & Video
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Problem with samsung plasma tv
hello ive just bought a samsung plasma off my friend and its about a year old and yesterday i set it up and get a fine picture untill about a hour or so of being on it starts geting blue sparkles round the outside of the tv mainly on the left side and seems stronger when sport is on ive tryed doing different things but nothing seems to work?i have also bin told that plasma tvs have to have gas put in them every so often is this true?i dont no which samsung model it is but it is 42inch and is full hd ready and is black with the round circle on the front of the tv can you help me?
Dec 19, 2007 | Samsung HP-S4253 Television
Dvd won't play through PACE hi def converter box, service electric cable ty
Why are you running hdmi to converter box? Run HDMI cable directly from dvd to new Panasonic plasma. The less things in between, the better the picture.
Dec 14, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
