Question about Video Game Consoles & Games
XBOX 360 DISC KEEP SPINNING WONT PLAY GAMES,HAVE TRIED DVD AND THEY WORK.
    Master:
  • 788 Answers
From what I've read, even if it plays DVD movies the laser is not working in the drive. There are tons of replacement lasers and drives on eBay and most of them come with instructions on replacing it and there are videos on YouTube. You're looking at between $25 and $50 for a new laser.
Posted on Aug 20, 2008
SOURCE:
Xbox 360 tray will work but wont read any discs .discs are spinning but wont play keeps comming open tray
Ok 90% of the time your console gives you the open tray icon when it tries spinning clean disks is because the laser has gotten to weak to read them. Your options are buy a new dvd drive or pot tweaking the laser which is relatively easy if you are not afraid to go hands on with electronics.
here is a good video on the tools you will need to open your xbox http://www.youtube.com/watch?v=Dtm7V4NotgA
Now first i would try cleaning it http://www.youtube.com/watch?v=Dtm7V4NotgA
if that doesnt work I would recommend pot tweaking and here is a tutorial for that http://www.se7ensins.com/forums/topic/93454-how-to-pot-tweak-xbox-360-dvd-drives/
honestly if you do not know much about electronics I would recommend just buying a new xbox dvd drive for like 20 bux off of ebay. But you will still have to open the xbox to figure out what drive you have and to actually swap it
Jul 25, 2011 | Microsoft Xbox 360 Console
My xbox 360 wont read disc any games at all just keeps saing open tray but will play demo,s
try to clean your laser eye with a dvd cleaner disc. If that doesnt work, you have a bad disc drive.
Dec 08, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
My xbox wont play any of my discs
there is something wrong with the eye. look it up on youtube and they will help you out
Mar 14, 2009 | Microsoft Xbox 360 Console
Unreadable disc
i used to think firmware but that is a very rare case. try getting a new laser, if that doesn't work swap the motor that spins the disc around but mark where the screws are before you remove them. good luck!
Jul 26, 2008 | Microsoft Xbox 360 Console
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 Disc drive
no that's not good the motor is working over time you need it looked at quick or the moter will give up and then it will be a bigger job more money try thhttp://www.gamevania.com/XBOX_360/repair.phpis site first.
Jan 03, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
54 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
