Question about Locks & Locksmithing
I have a Intelock digital deadbolt series 2000 lock that I can not re-set. I can not find a manual online. It is a different set-up from the 1000 and 3000 series. thanks.
  • 963 Answers
If you go to this site:
http://intelock.com/manual.htm
it will take you to the Customer Service page for Intelock, where there is a link to download the generation 2 lock's manual.
If that is not the correct manual, there is also a link there to contact their Customer Service, who i'm sure can give you the correct info for your lock.
Posted on May 18, 2011
How do i get the smartcode 909 to stop trying to lock continuously? It has already locked itself.
Mine did that when the deadbolt was not fully extending. Sprayed some WD40 where the deadbolt extends and locked/unlocked repeatedly to work it in. Tried again and no issue. Good luck!
Jul 27, 2014 | Kwikset 909 909-15 Satin Nickel Smart...
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I am looking for a manuals for a weiser lock powerbolt 1000 can i down lord
powerbolt 1000
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Apr 07, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Bolt doesn't open all the way
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Dec 13, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
My Powerbolt 1000 only works with the key in the deadbolt lock. I have a code entered that unlocks the deadbolt only with the key in the deadbolt. Your help is appreciated.
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Oct 17, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
The combination won't open the lock ...it takes 4 or 5 times to open the dead bolt all the way ...sometimes on the first try but mostly 5-9 tries .
Sep 29, 2010 | Weiser Lock Powerbolt 1000 Lock
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
How do i rekey the deadbolt to fit the doorknob key?
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Locks & Locksmithing Logo
161 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
