Question about Manitowoc Refrigerators
Manitowoc QD0132a ice machine makes 3 batches of ice thenshuts off
    Director Badge:
    Uploaded 100 video answers.
  • Manitowoc Master
  • 488 Answers
Posted on Aug 02, 2015
drknow
  • 44 Answers
SOURCE: making ice very slow and small
Hello, have you tried replacing the water filter? You did not say how long you have had this unit? What is your water pressure? Should be a minimum of 30psi. Good Luck! Dr. Know
Posted on Dec 23, 2007
  • 1073 Answers
SOURCE: the ice machine in our
what is the model number
Posted on May 05, 2008
  • 3074 Answers
SOURCE: How Do I maintenance a manitowoc series 150 ice machine
find the filter remove clean with water, coils should be shiney. This should fix the problem
Posted on Jul 23, 2010
  • 112 Answers
SOURCE: manitowoc series 100 makes ice but wil not go into
I'm not sure what you mean by a series 100. Manitowoc series are by the model number first letter. B-series, Q-series, J-series, etc. A 100 lb Q-series would be the most recent. If memory serves they started with A, C, E, G, B, J, S, and are now on Q. You can get most of the service books on their website here.
http://www.manitowocice.com/?xhtml=xhtml/mii/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
Sorry I cant be of more help without a complete model number.
Posted on Jan 04, 2011
heatman101
  • 43501 Answers
SOURCE: what is the operating pressure
That depends...
where in the cycle is it??? the pressures will change during the cycle...
What refrigerant is in it... they used a few different ones over the years...
Is it air or water cooled???
As you can see it is best to get an experience tech to check this out for you... and even then they can be a bugger...
heatman101
Posted on Jul 29, 2011
I have a Manitowoc J series and it will run three cycles and then shut off. I will start again and the same thing happens. everything else seems to be fine.
Chances are the unit is shutting down on an error code. It will shut down after three batches if either A: the unit takes too long to make ice, or B: a harvest cycle lasts too long. You can time a batch of ice with a timer or stopwatch... if you listen you should be able to tell when the "ice making" stops and the "harvesting" begins. Ice making should take about 13-15 minutes and harvesting 1.5 to 2.5 minutes. If I remember correctly the error codes are triggered if the ice making takes 60 minutes or longer and/or the harvest takes 3 minutes or longer. You can tell which error code is tripping by accessing the electronic control board. There is an LED indicator that will blink when you turn the unit on if there is an error present in the memory.
Oct 25, 2014 | Kitchen Appliances - Others
My manitowoc new ice machine is not making ice
Its plug and play. You need to call who ever sold it to you and have it checked out its under warranty.
Sep 24, 2014 | Manitowoc Indigo Ice Machine - Full Dice,...
Manitowoc QM 30 ice machine ice gets slushy
Water restricted somewhere. So 1st filter; 2nd water inlet valve. You need to deep clean this machines every 3 month.
Aug 15, 2014 | Manitowoc QM30 Under Counter Ice Maker
Manitowoc QY0135W is this ice machine spends to much water ?
it does drain out the tank what it does not use to make into ice; so in that sense, yes.
Jan 17, 2014 | Manitowoc QY0135W-251 Half Dice Water...
Manitowoc sd0602a keeps dumping the water 3-4 minutes after the pump starts, won't terminate freeze cycle or recalibrate. Have changed water level probe, ice thickness sensor and board. I suspect so
Make sure the water fill valve is shuting off for a while after start up . try turning off the water after it fills for one cycle and see if it makes a batch of ice
Nov 09, 2013 | U-Line Icemaker
Makes ice for 3 cycles then stops running.Can turn off then on again to make more ice for a couple more cycles.
check the cycle time for a batch of ice. should take around 15 minutes to freeze and then you will hear the harvest cycle kick in. If the harvest cycle takes 3 minutes or more that is your problem. You will need to get a hold of NICKEL SAFE ICE MACHINE CLEANER. DO NOT use CLR or any kind of cleaner other than NICKEL SAFE ICE MACHINE CLEANER. If the ice doesn't fall off of the plate in about 90 seconds either the plate is dirty or the nickel plating has come off. There is a failsafe shut down if the unit takes more than 60 minutes to freeze or more than 3 minutes to harvest 3 consecutive times. The cleaning instructions should be inside of one of the covers. If not it's available online.
Aug 15, 2013 | Manitowoc QY-0214A Self Contained Ice...
Won't make ice in cold weather
Check the thermostat of your Ice maker whether it is in working condition or not. For More information please visit GE Ice Machine Cleaner.
Nov 08, 2012 | Manitowoc 1400 Modular Ice Machine Sd1492n
Refrigerators Logo
120 people viewed this question
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
