My drive has power but the icon for it does not appear in the My Computer screen
...Power and data cables, you mean(two - both), Are your drive formatted?(New drives unformatted!).
First, restart your comp, after keyboard flashing, press DEL or F2 and start BIOS, All BIOSes are various, search byself in all menues/buttons Onboard IDE and SATA controllers configuration. All of them must be switched on(on diag time) and it's disk types must be AUTO, and large/LBA mode auto too(after change this param drive must be remapped and re-formatted with full lost of data). Also in ADVANCED submenu I recommend switch off quick self-test(POST). F10 to save changes and if all proper, BIOS must identify disk on boot screen.If boot screen splashed too quickly, go back to BIOS and look for disk parameters. If name of drive here is correct, and drive's geometry seems true, all is OK. If Win or other OS don't see this drive in DEVICE MANAGER/disc drives, then seems you obtain a non-standard device that require model-specific driver from manufacturer.
If drive exist in DEVICE MANAGER/disc drives, but OS don't draw it's partitions in My Comp, then it improperly formatted(part of RAID or virtual partition, or for other OS).Then it's need to new partitioning and formatting(All data become lost).
If BIOS don't see drive, something fail - Mboard, cables, or drive himself. There is one way to half-check drive without Mboard and cables. Plug it to power only, take him in hands, move it to your ear and turn on power switch. First you must listen increasing spindle noise, and after 1-10 sec from one to three head turns.( Modern drives has a noise protection,and sounds are quiet).If sounds differ from this, drive is bad. If heads turns more then 3 times, drive is near to death(half-year max), but still works. If heads don't sounds - drive's board is bad. If heads turns continuously - them or plates's surface are bad.Go to repair or drop off.
Described listening procedure is a self-test of drive and gives 90% sureness of it's goodness. Then try replug cables and test another drive instead for Mboard check. Somebody talks that latest drives don't work with old Mboards, but I never saw this.
Posted on May 17, 2011
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Green screen
Sounds like your hard drive may be faulty. Run the manufacturers free hard drive diagnostic software (from CD or USB drive to test)
Mar 31, 2014 | Acer Aspire E1-531-4444 15.6" Notebook...
When I plug in the harddrive to the computer, the usual "My Book" icon will pop-up on the desktop. When I click to open this icon the folder is empty and there is a processing icon that appears...
Hi Open computer icon and see if its there it should say expansion or something along that line, double click on it and see if your file are inside, the disc maybe labled F expansion drive
cheers
Paul
Nov 15, 2010 | Western Digital My Book Essential 1TB...
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
The power come on but the harddrive will not boot since there is nothing shows on the screen. The screen is blank, no apple sign, no sping gears. pls what do i do,and my mac os that comes with the system...
With regards to the blank screen, this usually indicates an issue with the hard drive being faulty (hardware) or the OS might have corrupt system files (software).
These are the items you will need before we begin:
A. Mac desktop/laptop B. Mac OSX Installation DVD
A. Software Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Skip down to Section B, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Follow the installation prompts. 8. Once completed, the desktop/laptop will reboot and after logging in, will execute the registration process. 9. Complete the registration exercise and access the desktop. 10. Perform a software update and download all system and application updates to their latest versions.
B. Hardware Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Restart the computer and skip up to Section A, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Close the installation application and select "Disk Utility" from the "Utilities" menu option. 8. When Disk Utility loads, look to the left-hand pane and locate your hard drive (if detected). If so, click on it and format the hard drive then reboot and skip up to Section A, step #1. If the hard drive is not detected, then the hard drive has malfunctioned and needs to be replaced.
Hard drive's cost from $40-100 for sizes ranging from 40GB to 1TB. Once the hard drive has been replaced, you can install OSX from the installation DVD.
Aug 11, 2010 | Apple PowerBook G4 Mac Notebook
Smartdisk 80gb has power connection, but data (Mac)
scan the your computer and smartdisk for viruses
the problem you are mentioning about the desktop icons could be due to viruses
also run chkdsk utility on the smart drive after virus scan
Jul 12, 2009 | FireLite (USBFLB80) Hard Drive
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
No icons appear when we turn our computer on
try this >>>
right click anywhere on your desktop, point your mouse to " arrange icons by" and in the box that will appear click "show desktop icons"
Oct 21, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
