Bang Olufsen Beosound 9000 - CD carriage will not move on command but does so randomly following a number of button pushes
  • 1 more comment
  • panda1512 Jan 17, 2009
    i have the same problem. The carriage moves to the prefered position but doesn't start. It ticks.
  • mshiehtw Apr 13, 2009
    i have the same problem. The carriage moves to the prefered position but doesn't start. It starts after several selections.
  • mshiehtw Apr 15, 2009
    I reset the Bang Olufsen Beosound 9000, and the problem is still there.
  • 122 Answers
Some odd problems with beosound 9000 can be caused by the finger protection device.make sure the 2 clear plastic towers at either end of the aluminium part are clean as well as the underside of the glass door between the 2 towers.
Posted on Dec 14, 2009
    Sergeant:
    Champion:
  • 319 Answers
Unplug unit for 12 hours to reset micro processor, then try again. Also install fresh batteries in remocon
Posted on Aug 14, 2008
I have beosound 9000 recently cd is getting stuck and doesnot go from one to the other
check finger protection.clean glass door along edge if dusty finger protection wont work and sledge wont move.
Jan 12, 2013 | Bang and Olufsen Beocenter 9300 Shelf...
How do I unlock B&O beosound 9000? Hi, have bought a beosound 9000 from a lovely gentleman who gave me a fake pin code and has since buggered off, not answered emails, or letters, or calls regarding...
You can only go to a b&o dealer to obtain a mastercode for the product, you can then change the pin code to one of your own.Proof of identity will be required along with the serial number and preffably the name and address of the original owner and where it was purchased.
Jan 10, 2011 | Bang and Olufsen Beosound 4000 Shelf...
Hi, I have a Beosound 9000 and it seems that the CD player is not able to run and I do not know what could have happened!!!::can you help me::please:::thanks. Thanks
IF THE DOOR SHUTS AND THE LASER ARM MOVES THE MOST LIKELY FAULT IS C2103 ON THE SERVO PCB.MAKE SURE THE CD IS CLAMPED PROPERLY BY THE CENTRAL HUB SPRING.
Sep 02, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
Beosound 9000 scratching top cd
You have to look up in the manual which way the two arrows on the underside of the unit are pointing when the CD player is located on the far right. The arrows are screw heads which appear in two holes on the underside. If, for instance, you are playing the unit lying flat on a shelf or table top, if you flip it up and forward to get at the arrows, the two arrows should both be pointing left. If you are mounting it on a wall, it's a different arrow combination. I had the problem you describe and this fixed it for me.
May 21, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
BeoSound 9000: Similar problem, AND no AM/FM/Aux either
sorry nothing straightforward springs to mind.A dealer repair seems the only solution.
Sep 16, 2009 | Bang and Olufsen Audio Players & Recorders
Can't play cd's
a new cd mech required,take to b&o dealer
May 22, 2009 | Bang and Olufsen Beosound 4000 Shelf...
Problem playing CD's
beosound 9000? have you moved the unit.this unit requires cd mech suspension adjustment depending on how it is placed,eg. vert. flat horizontal.check handbook and adjust as required.if it has not been moved then workshop repair needed
May 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Feb 15, 2009 | Audio Players & Recorders
1,488 people viewed this question
 Grubhead
Grubhead
