Question about Dell Inspiron 1525 Laptop Jet Black
Hardware scan shows failed surface scan test,targeted read test & smart short self test timed out,how to fix these problems
  • 64 Answers
These are problems that cannot be fixed, basically your hard drive is on the way out. Typically this is caused by drops, bumps, etc. while the machine is on.It has a SATA 2.5" 120gb 5400 RPM drive, I would suggest a larger 7200 rpm drive but it is up to you. You will also have to reinstall windows to the new hard drive.
Posted on May 17, 2011
    Problem Solver:
  • 5 Answers
This means that you hard disk has a problem. I suggest you contact a technician and replace your hard disk. In the meantime create backups of your valuable data.
Failed short smart self test shows number HD521-20. How to fix please.
Backup your data and replace the hard drive. There is no fixing this other than replacing the hard ware.
Mar 31, 2015 | Computers & Internet
What does Error Code: HD521-2W mean and how to fix it
http://h30434.www3.hp.com/t5/Desktop-Hardware/SMART-Short-Self-Test-Failed-Error-Code-HD521-2W/td-p/1181885
Nov 09, 2013 | Samsung SP2004C 200GB 7200RPM 3.5in 8MB...
Smart hard disc problome
It means pretty well what it says. That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual. Those things predict a hard drive crash, however it could take months for the drive to fail (or it could be the next minute). since it's a hardware problem the drive is going to die on you and you will have to replace it. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive. b> You could run the chkdsk disk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or an easier way to run the chkdsk utility click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now ,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
Feb 20, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
PRI master smart command failed
smart error predicted b> It means pretty well what it says. That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
open the laptop
get the drive out
Feb 07, 2013 | Microsoft Windows XP Home Edition
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Dell Dimension 2400 What is Targeted Read Test WHD-20-2RQ and Smart Short Self Test WHD16-FTD and how do I fix it if it said they failed
These are results of two sections of Dell Diagnostics tests which can be run by pressing F10 at startup.
You would have to watch them run to see what has failed during the test.
From Targeted Read Test WHD-20-2RQ failed, could be failure to read RAM (memory), CD/DVD Drive, or Hard Drive.
Something failing within Smart Short Self Test WHD16-FTD could literally be anything within the computer, without seeing what has actually failed during the test.
Sep 05, 2011 | Dell Dimension 2400 PC Desktop
During the monthly test: Hardware Diagnostics Tools- Scheduled Maintenance ... it shows that the surface scan test HD535-2W failed ...so do I need to fix this? and how???
actually it just test your hardware, but you can still use it, it actually says that bad sectors cannot be fix, something like that, try to scan it and fix error.
Sep 30, 2009 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Hard drive bad sector recoganisation
To check for errors and bad sectors on a hard drive, open My Computer,>right -click on the drive(for example D disk)>select Properties>select Tools tab>click on Check for errors button.
Apr 25, 2009 | ASUS P5PE-VM Motherboard
Diagnostic test failed
Most likely you can't...The SMART read stands for Self-Monitoring, Analysis, and Reporting Technology. If this test fails the hard drive will likely crash soon so backup what information you can to a CD-R or flash drive.
Nov 19, 2008 | Computers & Internet
Dell Inspiron 1525 Laptop Jet Black  Logo
846 people viewed this question
Alun Cox
