Question about Hotpoint Aquarius WF000 Front Load Washer
New board eeprom
Hi
I have a new electronic board for WF000G. It needs Eeprom with relevant software to operate machine.
I have the old board with a surface mount prom. There is space on the board to insert 8 pil DIL for new prom, plus pads for surface mount option.
My question is (I have e-mailed Hotpoint help line... useless!) how do I get a new prom for my board and what is the likelhood of original prom being OK if I remove and replace. I am an electronic enginner so have no issues with the de-soldering/soldering thing.
Many thanks
John McDevitt
    President:
  • 1,462 Answers
Eprom is available as a spare from hotpoint. however, there is a good chance that the old eprom is ok in my experience.
Posted on Aug 23, 2008
DAEWOO AIR CONDITION MODEL DSC-F1253L-V MINI SPLIT INVERTER THE UNIT WORKING FOR 3 MINUTES AND TURN OFF AUTOMATIC AND SHOW CODE FH. THE UNIT IS NEW. WHAT'S MEANS CODE FH. THANKS
The indoor EEPROM unit
1 ChecK whether there are false weld or bad connection etc, between the EEPROM chip block and electronic control board,
2 check whether the EEprom chip is broken foot and the direction of the installation is in line with EEPROM block.
3 When the procedure of EEPROM chip and itself have fault the code FH will appear. That is a need to replace EEPROM chip.
Dec 15, 2016 | Daewoo Heating & Cooling
I cannot connect an older version with the new ones I just purchased.
Hi luke,
Even though the model numbers are the same, the internal EEPROM may have an updated version of software programmed in them, which would cause the problem in communicating with the older radios, with every updated build of the radios, the EEPROMs are updated accordingly, so making things difficult for those using older versions of the same radios.
The only solution is to replace/upgrade the EEPROM in the older radios to the one in your new radio, do do this you will need to access the internal PCB and fing the EEPROM Model No. and the Version No., this is the version of the software programmed in the EEPROM, thus you can find the same EEPROM/Version at you local Radioshack or similar radio store.
Otherwise there's nothing else to be done.
If you buy another new radio, be aware, of the details I have posted here.
I hope this has answered your query.
Cheers,
Peter
Nov 10, 2012 | Kenwood ProTalk XLS TK-3230 Business Two...
My machine is displaying code F01. It comes up at the end of the wash cycle. However, It doesn't seems to be actually washing the clothes anymore. The water runs in and out of it , but I don't...
I tired answering yuor post and there is a problem with the website. I have reported same to the website staff. You should see my post via email soon
Kelly
Sep 24, 2011 | Washing Machines
Magnavox picture has started rolling.
You have a failing eeprom. The location on the board is IC002. The correct eeprom depends which microprocessor [IC001] and stereo decoder [IC1001] is used in your TV board. When removing old eeprom , insert a eight pin socket and solder into place. Now you may insert the new eeprom. This will be handy the next time you need to replace this IC the next time!
Jul 04, 2010 | Philips Magnavox 27MS343S 27" TV
I have a F-01 fault code on my Kenmore HE2plus front load washer. model # 11047512601. Sears talked me thru the software resets and still had the F-01 error. do I need to replace the Main Control Unit?
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Thank you !!
Jun 28, 2010 | Kenmore HE2 Plus Front Load Washer
I have a F01 code
Apr 13, 2010 | Kenmore HE2 Plus Front Load Washer
This console has been banned for violations of the Terms of Use. To protect the Xbox LIVE service and its members, Microsoft does not provide details about console bans. There is no recourse for Terms of...
You must do the following to get access for free:
requires a virgin xbox that has not been banned (a friend's) and somewhat knowledge about computers.
Banned Xbox Live Fix - New EEPROM ' (Old Tutorial)
To get unbanned you need to purchase a new xbox EEPROM(pal or ntsc). Steps for installing it are listed below. IT WORKS. Just make sure your orginal MS info is correct and your modchip is turned off.
GETTING THE EEPROM FILE FROM THE UNBANNED XBOX
(TO INSTALL YOUR EEPROM, MAKE SURE YOU ARE USING CONFIGMAGIC FINAL* ALL OTHER VERSIONS ARE BUGGY AND WILL CAUSE PROBLEMS. ALSO, DO NOT USE THE SOFTWARE: EEPROMER)
[This is only if you want to backup your original eeprom file]
1. In EvolutionX, do the "Backup" command in the Utilities menu. It will generate files about your Xbox specs.
2. FTP in your Xbox, or use a file manager tool, and in C:Backup, you will find a file called EEPROM.BIN
3. FTP that to your PC HD or remember its location for future reference.
SETTING UP THE FILE FOR CONFIGMAGIC FOR THE BANNED XBOX:
1. Once you have Configmagic loaded onto your HD or on your PC, there will be a directory in it called DATA.
2. Move the EEPROM.BIN file, the new unbanned EEPROM you purchased, into that DATA directory, overwriting the EEPROM.BIN file that is already there.
3. If you are making a Configmagic CD, you can now make the ISO of it and burn it. Xbox HD users, don't worry.
RUNNING CONFIGMAGIC:
1. Load up Configmagic.
2. A warning screen will be shown, press "A" to bypass it.
3. When Configmagic finally loads, it will show your current EEPROM on your Xbox. Make a note of the DVD KIT ZONE and VIDEO AND XBE REGION information. "NTSC, Region 1" for US Xbox gamers "PAL, Region 4" for UK Xbox gamers
4. Select "LOAD XBOX EEPROM" in the menu.
5. Select "UNLOCK HD" in the menu.
6. Load the EEPROM.BIN file in the DATA directory by choosing "LOAD EEPROM FROM .BIN FILE"
7. If you see that the VIDEO AND XBE REGION information is different, you MUST change it. Go into the menu and choose "ON-THE-FLY EDIT EEPROM". Change the VIDEO AND XBE REGION number to the proper information of your former EEPROM.
8. Now, select "UPDATE XBOX EEPROM" in the menu.
9. Your Xbox's EEPROM will now be updated with the file in the DATA directory.10. In the menu, select "LOAD XBOX EEPROM". You will notice your EEPROM is now different! Success.
11. Select "LOCK HD" from the menu.
12. Select "EXIT CONFIGMAGIC" in the menu.
IMPORTANT TIPS:
- If you were using the XBOX DVD KIT to play DVDs, and the Xbox gives an error about region, load up Configmagic and change the DVD KIT ZONE number to the number of your previous EEPROM. UNLOCK the HD, choose "ON-THE-FLY EDIT EEPROM" in the menu and simply change the DVD KIT ZONE number. Then, UPDATE XBOX EEPROM and LOCK HD. Exit Configmagic.
- You can view any Xbox EEPROM using your PC by getting Liveinfo PC program. It will show all the details of an EEPROM.BIN file. You might find it easier to edit any possible changes to your DVD KIT ZONE or VIDEO AND XBE REGION using the program, rather ON-THE-FLY EDIT EEPROM in Configmagic.
- Sometimes, with a PAL EEPROM, your Xbox's time might be wrong or video settings will be different. Go into the MS dash and change the settings to the way you seem fit.
Special Notes:
- If you were banned with your original eeprom, once you replace your eeprom, you will need recover your account. To do this, simply select the account recovery option. Once this is done, you will need to verify some personal information in order to retrieve your account.
Nov 07, 2009 | Microsoft Xbox 360 Console
I-INC CY199D lcd monitors will not turn on or off
find a electronic repair shop and ask them look up the ic number. if they they can read the program of of the old chip, they can put it on a new eeprom. somtimes the chip wont work but can still be read..
also have tried to find the board it self on a lcd parts web site? http://www.lcdparts.net/
also you may want to see if ebay may have a scratched up monitor of your or one they has a power supply problem.
Aug 11, 2009 | Computers & Internet
Need to locate eeprom.
Hi there.
EEPROM stands for Electrically Erasable Programmable Read-Only Memory. An EEPROM is like an EPROM chip since it can be written in or programmed more than once. Unlike the EPROM chip, however, an EEPROM chip need not be taken out of the computer or electronic device of which it is part when a new program or data needs to be written on it.
The BIOS is the EEPROM chip, so you have to note what BIOS version it is AMI, Pheonix for example, this chip is located on the laptop motherboard and will be clearly marked.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq 6710b Notebook
WF000G Board
i have the same prob i know where they go on the heater element but where do they go on the pcb
Aug 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
323 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
