Question about Canon Office Equipment & Supplies
Canon MP495 alarm light on suggest cartridges are not aligned properly, as well as 'color ink' lamp is flashing orange, how do I fix this?
Tonerman
  • 62 Answers
SOURCE: Error after reloading color ink
try re-installing the printer freshly with the driver .
Posted on Jun 10, 2007
SOURCE: Ink Cartridge Refill Error E5
First take a smooth cloth or cotton
take a cleaning liquid like spirit, thinner etc., (note - not cleaners)
clean the golden chip with out giving much presser
in the same way clean the other side of the printer also
now test it
90% Problem will solve
Thanku
Take care
Bye
Posted on Apr 18, 2008
SOURCE: Canon i9950
Five flashes: Print head not installed / Print head not installed correctly / Defective print head
Install the print head. If the print head is already installed, remove the print head and check the electrical contacts for foreign matter, then reinstall.
For the i9950 ONLY: When the CD-R tray is set in the printer, remove the CD-R tray and set the paper output tray to the paper print position, then install the print head.
After reinstalling the print head, you may need to realign it.
If this error still remains, the print head may be damaged
Posted on Jun 23, 2008
  • 66 Answers
SOURCE: override alarm for color ink cartridge
Hi Redtail,
Try the following. It will not disable the alarm but will reset the in counter.
  1. Power off the printer
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Release power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace.
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through
  14. then set language and counrty.
  15. Then ink should be reset
Posted on Dec 22, 2008
dejoebad
  • 4 Answers
SOURCE: In canon pixma ip1700 Alarm light orange flashes 15 times
i've post a solution here in fixya. same condition with u. just do a temporary reset. it explained there. c ya......
Posted on Jun 03, 2009
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Canon iP2600 Printer yellow light flaxes message says an ink cartridge is not installed properly
have you tried cleaning the printheads ?
There is an option for cleaning head in printer's properties : select this and you will be able to clean printehads for the canon iP2600
Jan 19, 2012 | Canon Pixma iP2600 Photo InkJet Printer
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    The color ink cartridge that is " blinking " is
    Don't buy Canon as they absolutely ROB you for the ink!! They are worse than ****** dealers! At least HP allows you to use non (rip-off) OEM cartridges without all the hassle! My printer will be thrown out after the ink runs out as I will not be ripped-off by Canon again!
    Apr 30, 2011 | Canon Pixma MG5220 InkJet Printer
    7 orange flashes and then one green..what does that mean?
    7 orange flashes of the alarm lamp means that FINE cartridge is not installed in the correct position. Confirm that the FINE Cartridges are installed in the appropriate positions.
    Please refer to the link below to see document on replacing FINE cartridge http://support-ph.canon-asia.com/contents/PH/EN/8200182600.html
    The link below gives you information regarding Causes and Solutions when Alarm Lamp Flashes Orange http://support-ph.canon-asia.com/contents/PH/EN/8200187300.html#5
    Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
    MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
    Check the status of each cartride by using the ink lamp.
    You have 3 lamps
    (A) Alarm lamp
    (B) Black ink lamp
    (C) Color ink lamp
    Make sure that the LED is on standby mode.
    a) If the ink lamp lights.
    Cause : Ink is low.
    Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
    b) The Alarm Lamp lights and the ink lamp flashes .
    * If "E, 1, 3 " is displayed on the LED, ink has run out.
    Cause : Ink level cannot be detected.
    Action : Ink may have run out.
    The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
    If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
    Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
    * If E,1, 6" is displayed on the LED,
    Cause : Ink has run out.
    Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
    If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
    The function for detecting the remaining ink level will be disabled.
    Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
    c) Only the ink lamp flashes
    Cause : The function for detecting the remaining in level is disabled.
    Hope this helps.
    Please rate my response.
    Thanks
    Have a good day.
    Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Fifteen Flashes: The FINE Cartridge cannot be recognized.
    Possible causes are as follows:
    - The FINE Cartridge may not be installed properly.
    - The FINE Cartridge may not be compatible with this printer.
    Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
    Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    The orange lamp always lights
    depending on how many times the orange light flashes. if 4 flashes then the ink has run out. if 5 flashes then it can not recognise the ink cartridge, if 7 flashes then the ink is not installed properly.
    Mar 31, 2009 | Canon PIXMA iP1800 Printer
    317 people viewed this question
    old marine
    old marine
