Question about Car Audio & Video
My 2006 LEXUS RX330 Audio Head Unit - Pioneer 86120-OE050 / FX-MG8947zt, did a electrical clip in the dash and lost the sound. The Audio display unit for the Radio and CD is working but there is no sound. Can you help me about the possible cause o fault, Thank in advance
SOURCE: No XM Audio, no fault indication
Buss cable is plugged into the wrong connector on the GEX-P920XM. The installation manual is not clearly written, the figure in the manual is correct.
Posted on Feb 25, 2007
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
sgregg
  • 133 Answers
SOURCE: Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Posted on Jul 30, 2007
SOURCE: ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
Posted on Aug 06, 2008
  • 247 Answers
SOURCE: Pioneer AVIC-n1 touch screen display failure
when those screens go out you are better of replacing the unit. they cost more to repair then buying a new one. also with pioneer they seem to only last 5 to 6 yrs. so if yours is a 2004 then it is about time for it to start to have problems and time to buy a knew. it seems with pioneer they only lasts 6 yrs max and then you have to replace them but other brands like solny they last a lot longer.
Posted on Jan 07, 2009
I have a Lexus Pioneer car stereo head unit (KEX-M9161ZT) with cassette unit that Im trying to check out on the bench.
Most unit have RCA outputs that go to an amp.. There are sometimes a mute wire in the harness that goes to the control section. You need to have the service manual to work on these as there are few standards of wiring. Any home integrated amp or receiver should be able to handle the signal once it comes out to supply to speakers. Car players are many times full of broken solder joints. I looked for a picture of the unit but it must be old enough to not have much support.
Jun 26, 2016 | Pioneer Audio Players & Recorders
Cooling fan continunity check ???? One has continuty other does not ??????
  1. Lexus RX 330 04 05 06 Radiator A C AC Cooling Fan with ...
    www.ebay.com > ... > Cooling System > Fans & Kits
    eBay $138.25 - ‎In stock
    Lexus Rx 330 04 05 06 Radiator A/C Ac Cooling Fan With Control Module 8925730070 in eBay Motors, ... 2004 2005 2006 04 05 06 LEXUS RX330 , RX 330 ...
  2. images for 2005 Lexus RX330 cooling fansReport images
Sep 21, 2015 | 2005 Lexus RX330
My LEXUS RX300 has a factory PIONEER KEX-M8006zt. The TOYOTA Number is 86120-48090. will not turn on. None of the buttons, may they be for A/C, NAV, or radio, work. You can press them all day long, but...
Hi altech1,
If you confirmed that the fused are all working then the problem is internal within the unit itself. The most common reason why it will not power up because its power supply was dead. The unit has also an internal fuse(glass or ceramic)/or fusible resistor in line with the supply from the battery. Once this failed it will disable the unit. You have to take it apart and check for fuse and fusible resistor.
Another is the bad power on switch. This may have a dirt build up which no longer have a contact.
If you don't have necessary tools and test instrument and can't troubleshoot it yourself, I would advice you to look for an experienced technician to isolate the problem...
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 16, 2011 | Pioneer Car Audio & Video
My 2004 RX330 Navigation GPS DVD does not load
another thought is try disconnecting the battery for and hour or 2 and see if that resets it,your last resort may be (hate to say it ) dealer to look at it
Oct 24, 2009 | 2004 Lexus RX 330
Slight vibration feeling
is it a buzzing type sound? That can happen both the driver and passengerside. there is a white clip that locks the dash to the firewall. you need to get at it as stick a piece of felt to stop the vibration. but it is very tough to reach..
Jun 18, 2009 | 2004 Lexus RX 330
Remove basic unit from the housing in the dash
you need two little flat pieces of metal that slide down each side of the unit to release the clips these come with the radios usually if you know anyone that has purchased a pioneer head unit you should be able to borrow them to do it. if not go talk to any install shop they have them laying around and will sometimes part with them. if you cannot get ahold of them you will have to remove your dash and pull the bolts out and remove the entire chassis to get at the back then reinstall it. you did not say which car you have so i cannot help with the dash removal.
May 15, 2009 | Pioneer DEH-P2500XM CD Player
Cracked screen on 2004 lexus rx330 nav unit
UNKNOWN BUT TOO REPLACE
IF YOU CAN SEE THE RADIO DON'T REPLACE IT
BUT ITS A LEXUS THE CAR IS 1 OF A KIND IT SELF BESIDES THE CRACK IN THE RADIO
GET A NEW 1 WITH BLUETOOTH by ALPINE and get yo stunt on its 2009
THE WORLD IS CRACKED NOT NAVIE GLASS
Apr 07, 2009 | 2004 Lexus RX 330
Dash Panel around the audio unit and climate controls PLEASE HELP!!!
just pull on it its pressure clips that hold that no screws when its gonna be off you gonna have to remove the electric connector to lighter 4 bolt easy job dont be afraid to pull on panel hope its a fix for you and a fixya rating for me thank you pierre if any other question about malibu or mechanical dont hesitate ask a expert pierre235
Aug 03, 2008 | 1998 Chevrolet Malibu
Car Audio & Video Logo
109 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
