Question about DigitalBox Europe Electronic Digital Box Safe Jewlery + Guns Programable
After replacing batteries safe code won't work
Windows won't start with safe mode
Download a new safemode for dell. my safemode wouldn't work too.
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
Safe(DSW3607). Battery is working but door won't open when combination is entered. It stuck in the past but I was able to open it eventually. Now it appears as though the handle will not turn all
Internal batter is low...look for two pin points on the outside of the combo and attatch a new battery temporairly then work combo. Insert new battery when you get it open. Hope this helps Ed
Oct 02, 2012 | Sentry Fireproof Safe
Can't open hardline safe
Usually if your code has worked in the past it is a bat problem. Try purchasing a cheap bat tester to verify bats are good. Once verified with good bats try code again if still not working there are other steps that can be taken. Hope this helps.
Sep 06, 2012 | Computers & Internet
My radio won't work after replacing battery.
Could be needing a security code. Did you look in your owners manual ??
Jul 04, 2012 | Chevrolet Cars & Trucks
2000,Jag xj8, throwing codes P0172, 175, rich both banks. Checked injectors for leakage, good. Check EGR, EVAP, good. Checked fuel return line good. Checked fuel pump pressure good, checked throttle...
Hi
It is a rich condition for both a and b banks, you need to look at things that feed both. That code is most often MAFS, but you need monitor fuel pressure. Even more important is your long term fuel trim may be still under old operating conditions. Disconnect the negative battery cable and momentarily touch it to the positive cable to provide a path to ground for the capacitors and erases volatile memory in the ecu's. Then you won't be dealing with past parameters the ecu.s use for performance changes...A fuel pressure reg. is a likely culprit too
Undo your negative battery terminal for 30 minutes then re connect it. This should clear any fault codes. the exception is if there is still a problem then it won't work.
Also check this link for more info:-
http://www.bba-reman.com/content.aspx?content=NEXT_DTC_P0172
Please get back to us if you have further query or else please accept the solution.
Sep 07, 2011 | 2000 Jaguar XK
When I go to turn on the radio it just reads "safe" and won't work or play anything. AT first i thought it was a battery issue but the battery has been charged and works great yet the radio...
IMPORTANT NOTE:
You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of Audi radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Jun 07, 2011 | 1988 Audi 80
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
DigitalBox Europe Electronic Digital Box Safe  Jewlery + Guns Programable Logo
43 people viewed this question
Top DigitalBox Europe Home Security Experts
Lawrence Oravetz
Are you a DigitalBox Europe Home Security Expert? Answer questions, earn points and help others
