Question about Directed 434MHZ Remote Control
I have Janesong remote controler I cannot programme it on my LG TV, I tried with SET button, and also by pressing No. 5 but it only changes channels from 0 to 5 to 11 and nothing happens. HELP!
Efectuar ligação com TV
Posted on Jun 19, 2011
Como programar el control remoto universal janesong JS-6212A
0233 0237 0436 0673. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
May 02, 2014 | RCA Universal Remote Control
Hi i need to find a sky plus code 47lh300-za for this LG TV can you help?
Hello
Setup codes for LG TV with Sky are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4*Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Jul 21, 2011 | LG 47LH3000 LCD TV
Sky remote control code needed for lg tv - model 37lk450
Hello
Setup codes for LG TV with Sky remote are:
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Jul 16, 2011 | Televison & Video
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. http://www.remotes.com/store/orion/tv1934.html is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
I have a Nexxtech IT009 remote and a HTS Dish Network converter box. What is the remote's codes and how do I program them?
http://www.tivocommunity.com/tivo-vb/showthread.php?s=&threadid=128743
Above are all the codes for the HTS box,one of these should work with your remote.
Nexxtech codes below.
www.jascoproducts.com/support/download.../RemoteCode-4-digit.doc
Try using the code search to programme your device.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the P (Program) button until the red indicator stays on. Release the P button.
3. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stayslit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channels. If you accidentally overshoot the desired code, press the Channel Down button to backtrack through the library until the device changes channels. Pressing Channel Up changes the direction to forward again.
5. Press and release the Enter button to set the code.
If you still need a code list email, support@orbyxelectronics.com or call 1-866-363-3059.
Aug 13, 2010 | DISH Network IR Remote Control
Have a sony universal remote model RM-V401 trying to set code for a phillips tv
Procedure to programme Sony universal remote RM-V401 to philips TV are
1. Turn on the component to be programmed.
2. On the remote control, press the SET button.
3. Press the appropriate component button for the component being set up.
4. Using the number pad, enter the component's manufacturer code.
5. Press the ENT button.
6. Point the remote control at the component.
7. Press the POWER button to verify operation.
Code for philips TV are 011 043 056
Thanx
Aug 06, 2010 | Philips Televison & Video
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
9) To Check if it was a success
Jun 21, 2008 | LG Televison & Video
Televison & Video Logo
528 people viewed this question
Top Directed Televison & Video Experts
Christopher Stearns
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
