Question about Quinny ZAPP Stroller
Have loosened the screw holding the black fabric tray in place not realising it holds the piston that is part of the folding mechanism in place, now its not in place? How do I get the piston back in place to screw the nut back?
  • Quinny Master
  • 1,629 Answers
Good Evening
The product would need to be sent to the engineers for them to provide full inspection & repair of this.
What country are you in?
Posted on May 23, 2011
How do I change the needle on my Bernette 303 overlocker
To be sure you don't drop the needle down inside the machine, place a piece of paper or fabric across the needle plate. There are 2 tiny screws above the needles. One does the right needle, the other does the left needle. Loosen the screw (do not loosen the screw so much that it will fall out--they are Hard to find!). Pull out the old needle. Push the new needle up into the hole (the flat side should face the back of the machine). Hold the needle in place while you tighten the screw.
Bernina Bernette 303 334D 335 Serger
Aug 14, 2017 | Sewing Machines
The thread guide of my Elna Lotus has fallen out - how do I put it back?
Is this one of the Swiss metal Lotus models with the fold down flaps and a metal thread eye which sits under the lid of the accessory tray? If so, its pretty simple to unscrew three or four screws which hold down the accessory tray and flap on top of the machine and then replace the metal thread eye back into position, there is one screw which holds a plate on the underside to keep it in place from memory.
Jan 24, 2015 | Elna Sewing Machines
My Toyota rs 2000 was working fine until i decided to dust and oil the machine. I opened up the machine and realised the amount of dust in it already especially around the feet dog so i cleaned it and...
Is your machine equipped to lower your feed dogs
? You may have lowered it by mistake, or your bobbin tension spring may have loosened? I hope this helps? Happy Thanksgiving
Nov 22, 2013 | Sewing Machines
How do i install the darning foot?
Make sure that you have a darning foot that is compatible with your machine. I believe that the 7422 is a low shank foot; the appropriate daning foot is http://www.sewingpartsonline.com/darning-foot-singer-006016008.aspx . Lift the presser foot and remove the foot currently on the machine, including the ankle. (Loosen the screw on the left side of the ankle.)
Place the darning plate over the regular plate and feed dogs. The pins should lock into the spots on the machine.
Place the U-shaped opening of the darning foot over the screw that you loosened previously. Then tighten the screw to hold the foot on the machine.
Lower the presser foot onto your fabric. Set your stitch length. Lower the lever on the right side of the darning foot and hold onto your top thread (assuming the needle and bobbin thread are already threaded.) Now sew.
I hope this helps.
Aug 10, 2011 | Singer 7422
How do i change the batteries on a cyberman toy helmet
On the top at the back a very small screw holding the battery cover in place.
Sort of Philips screw hard to get out.
Batteries probably corroded but should clean up. If springs have disintegrated a folded up bit of Bacofoil will suffice. Good luck.
I removed the circuits box before I realised where it was??
Jul 09, 2011 | Toys
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
The fabric softner chamber seems to be clogged because after a wash it is full of water.
The fabric softener chamber is likely full of crud and or mildew.
  1. Pull out the detergent / softener tray (press down on the tab in the back to get it all the way out). Take it and wash it as well as you can.
  2. Now, pull the washer out enough that you can get to the back of the machine.
  3. Unplug the washer!
  4. Remove the four screws holding the plastic tabs (at the top) on the rear of the machine.
  5. You should now be able to remove the top cover of the machine - slide it back and then up.
  6. There are four small hoses connected to the back of the detergent tray, and one large hose.
  7. Take a marker / tape / etc. and label these hoses 1,2,3,4 - write the corresponding number on the top of the detergent tray so you will know where to hook them back up!
  8. Using pliers, squeeze the tabs on the small clamps to loosen them enough to pull them back about an inch on the small hoses.
  9. Pull the hoses off, gently.
  10. Use a phillips head screwdriver to loosen the clamp on the large black hose. Pull it off.
  11. You may want to loosen the other end of this large black hose and remove the hose for cleaning. Mine was nasty.
  12. There is a black bundle of wires snapped into the sides of the detergent tray. Take this bundle out of the clips so it hangs loose.
  13. Remove the two screws from the front of the detergent tray. These are on either side of the opening and are usually hidden by the detergent drawer.
  14. Now, you should be able to slide the entire fabric softener tray back and out of the machine.
  15. The tray comes apart into two pieces - gently pry the tabs on the sides to separate them.
  16. Clean everything! If anything is too nasty / clogged to clean, buy a replacement part.
  17. Reverse steps to reassemble and good luck!
Apr 29, 2010 | LG WM-2277HW Front Load Washer
How do I change the right brake light/stoplight?
In order to replace the light bulbs you will have to remove the entire rear light housing unit. In order to do this you must do the following:
  1. Pop the trunk.
  2. Loosen the trunk lining in order to reach the 4 nuts that are located on the right or left side and hold the light housing in place.
  3. You loosen the trunk lining fabric by removing two small, black plastic fasteners that anchor the trunk lining fabric. These either screw loose or you will need to pop off using a blunt- nosed pliers ( a flat head screwdriver works in a pinch) by first pulling the square bit out (towards the direction of the back seat,) followed by the circular components.
  4. Pull the fabric loose on either the left or right side to expose the 4 nuts holding the light assembly in place.
  5. Now, look for the four gold colored washer and nut assemblies surrounding the tail-light assembly. Find yourself a 7/16 socket and remove those bad boys. The tail-light itself should be able to pop- out, otherwise you've missed a washer- nut.
  6. Ease the tail- light assembly off of it's perch on the car and hold it red- side down. This will expose the wiring and "turn- locks" for the blinker and tail- light.
  7. Remove the bulbs from the assembly by turning the turn- locks in the direction (counter- clockwise) indicated by the plastic molding, and pulling upwards, off of the tail- light assembly.
  8. Pull the bulb from the turn- lock with a moderate tug of the hand.
Aug 04, 2009 | 1997 Mercury Sable
Quinny Buzz Jogger Folding System
Before you play with it any more be aware that Quinny frame has a 2 year warranty. Avoid damaging your warranty and contact the retailer.
Jul 02, 2009 | Quinny Buzz Jogger
How do you change the low-beam light bulb on Subaru Tribeca? Cant get the headlight assembly out. Have taken the two screws out, but something else holding lower corner.
I just had to do this and learned the hard way.
First take the battery out.
Second remove the plastic cap covering the low beam bulb
Thirdly there are 2 screws holding a wire tension spring against the bulb. Losen the screw towards the outside of the car (Don't touch the screw closest to the engin).
Once you do this, the bulb will come out and you can replace it.
Jan 14, 2009 | Subaru Tribeca Cars & Trucks
Quinny ZAPP Stroller Logo
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
