Question about Kenmore Top Freezer Refrigerator
There is a burning/electrical smell perhaps once a day, I was thinking maybe a defrost cycle or something? Is this a dangerous thing?
  • Kenmore Master
  • 3,361 Answers
If it occurs about the same time each day and there are no cooling issues,it is most likely the defrost cycle and nothing to worry about.
Posted on May 17, 2011
Testimonial: "Thanks for your very prompt response. My wife will hopefully leave me alone now and not deman a new refrigerator."
Maytag Neptune MAH5500 smelled like burning plastic at the end of the cycle. (The whole basement smelled bad.) The smell seemed to be coming from the plastic part at the top where it latches.
Tub bearings get worse, if they faulty, the machine would be noisy and getting louder. Sudden burning smells usually mean an electrical failure of a component but if this has stopped and the machine is working properly, its possible that something has got caught up in the rim of the tub or gasket area and during spin it has got "burnt" by being dragged around the edge. Have a close look at your clothes that were washed on that day for signs of burning or damage and around the top at leading edges of the tub for signs of melting or damage.
Mar 21, 2017 | Maytag Washing Machines
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
I have a dura flame electric fireplace and I turned it one and it smells like something is burning. I tried to vacuum it and I turned it back one and it still smells like something is burning. it is a
when things are brand new that produce heat they will smell funny for awhile but give it a couple days and it will not if you see smoke then get excited and unplug.
Jan 28, 2015 | Duraflame L Electric Stove with Remote
Did not go into the spin cycle and smells like something burning
when m/c goto spin the motor load is maximum i hope no thing with your motor
also if you smell like rubber burning maybe the belt , you will surprise every thing you see come after heavy overload clothes
Jul 06, 2009 | Washing Machines
Whirlpool Ultimate Care II washer went dead during fill cycle
Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
Bosch SHU33a won't drain
Try pouring in enough water to cover the screen in the bottom of the dishwasher, maybe a 2 quarts or so, then run the drain cycle. This should prime the pump and at least tell you wether the drain pump is working or not. Just a trick i've heard and worked for me, not my area of expertise however.
Jan 05, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
Dryer not working all the time
99% of the time , a buzzing motor means the motor is almost burned up. Especially when you can smell it. A burnt motor calls for more current due to the laws of electricity and this overheats the motor windings and this is what you smell. If you are lucky, one other thing can cause a motor to buzz. Something is binding somewhere and the motor is not strong enough to turn the shaft. You would smell this also, but if you can find what is binding it and remove it, then you should be ok if you have not used it too much with it smelling. Look for a sock or wash rag tangled inside the dryer between the drum and the inner walls. This extra "drag" would cause the symptoms you are seeing, but something tells me that you have a burned up motor.
Mar 03, 2008 | Dryers
Kenmore Top Freezer Refrigerator Logo
141 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
