Question about Sharp AR-168S All-In-One Laser Printer
I have a Sharp AR-168S that is displaying a message saying "Maintenance Required. Call for Service." and the red triangle light is lit. Is there a fix for this?
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
I have a problem with sharp AR 6020 photocopier machine that is displaying triangle and minus symbols how can i solve it
The Triangle may be the toner low light. On the older models it would look like a Triangle of stacked up cannon balls. I am not specifically familiar with your exact model.
Feb 19, 2017 | Sharp Office Equipment & Supplies
The little red triangle is lit up
OK, but what is the message?
Like change toner, maintenance required,...?
Jun 25, 2010 | Sharp AR-M205 Copier
My ar168s doesn't work with my iMAC, so I can't
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Have you tried this site for drivers? If the copier function doesn't work, then neither will the print function.
http://www.sharpusa.com/files/cop_man_AR168S_AR168D.pdf
Does the machine display an error code? It is difficult to give a guestimate on repairs without some idea of nature of failure.
Sep 02, 2009 | Sharp AR-168S Copier
How do you reset preventive maintenance message?
Hit P * C*
press 20
hit start
press 01 or 1
hit start
hit CA to exit
This is the "Maintenance Count Clear" sequence.
Aug 12, 2009 | Sharp AR-168S Copier
Need code to reset AR 168S copier
yes i know you press c photo c photo then all light is off press up and down arrow key
Jun 11, 2009 | Sharp AR-168S All-In-One Laser Printer
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-168S
check in the exit part of the machine, front edge there is a holding pin that may not be removed. it should just unscrew to release the scaner. (it should be blue or green).
Oct 24, 2007 | Sharp AL 1631 Copier
Sharp AR-168S All-In-One Laser Printer Logo
136 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
