Question about GE Microwave Ovens
Where is the gas inlet located on a GE 24" gas range Model JGA s02s?
  • GE Master
  • 1,902 Answers
Hello & Welcome to FixYa
Check these parts image to locate the gas inlet. Please get back to me if you have any other questions.
Kevin
Posted on May 17, 2011
Have GE Spacemaker XL1800, Had a power outage & now it wont power up. No lights or anything. Checked the 2 fuses behind the control panel & both were good. Any other suggestions or should I just chuck it.
In addition to the fuse(s), it will have one or two thermostats (aka "thermal cutouts" or "TCOs") which can open, resulting in a loss of power.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpg You can see a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Along with the video there, you can find information on getting your controller repaired, if that's what's required.
You find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Oct 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Over the Range Lights & Fan Failed. GE Microwave Oven JVM172G
It's not a fuse issue.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We see and repair this a lot. The problem is on the control circuit board.
You can have it repaired or replace the smart board yourself.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes. Then...
Some connectors have a lock.
Then you remove the defective board and install the new one in your frame. Be careful, since the display is made of glass.
Jan 29, 2013 | GE SpaceMaker Microwave Ovens
JVM231WV001
It sounds like instead of an overheated magnetron thermostat tripping the power, you now have a defective door switch.
Our door switch help file is here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 27, 2012 | GE Profile Spacemaker Over-the-Range...
The features "reheat", "beverage". and "popcorn"
Chances are you have a bad gas sensor (humidity sensor).
Jan 17, 2011 | GE Microwave Ovens
I would like to upgrade one of my burner grates for a GE "Gas Slide-in Range (Model #JGSP20). The individual burner grates are 8 5/8" square and 7/8" high. I would like to locate one...
Hi!!
A new OEM grate for your unit will cost about $62.00 + S&H at this place http://www.repairclinic.com/PartDetail/Grate-or-Griddle/258336
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 08, 2011 | Microwave Ovens
My GE Microwave Oven, installed 2 years stopped working, and Displayed "F3". Model #: JNM1851DM2BB How can I solve this problem? Thanks
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is part number WB07X11020 and you can order it for $105.61 from the Pros here.
It's not currently in stock, but they can have it in a few days. They're our favorite supplier.
At our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame.
Some connectors on the relays have a lock. See that image here:
Dec 31, 2010 | General Electric Microwave Oven
Have a GE Profile Micro, model# jvm2070sk02, serial 3 tl901189b. Error message F5 Humidity sensor not working. No manual
You can find helpful exploded view diagrams and order parts (such as a new humidity sensor / gas sensor) by entering your full model number
here.
Oct 29, 2009 | GE Microwave Ovens
Ge jvm1540dm2ww over the range unit: have a gas range and the fan on the above mounted microwave once in awhile turns on automatically while something is cooking on the range below it....
The heat sensor in the electronics panel senses the rise in heat from the stove below. Once the amount of heat reaches a certain level, the cooling fan turns on to keep the electronics inside the microwave cooled.
I wouldn't worry about it. mine does the same thing.
Jun 19, 2009 | Microwave Ovens
We have a GE Spacemaker 2.0 Over-The-Range Microwave Oven. It has power, and the keypad display appears to be normal at first glance. None of the keys or buttons are operational, however. In all...
You will need your model number, which will be something like JVM1840WH01, etc.
You may need a hard reset. Unplug the unit for a minute or so then try again.
Aug 28, 2008 | Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
