Question about Pioneer DV120K Player
Pioneer dv-120-k DVD player is not multi-region, as claimed everywhere on the internet. what is the way to make this player region free?
SOURCE: Unlock codes for Pioneer DVD player
Pioneer DV-667A
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
Posted on Sep 16, 2008
  • 9 Answers
SOURCE: Pioneer DV 393 no region free
I think that the general unlock is:
Open disk drive> press 1,2,3,4 on remote> close disk drive
Worked on mine.
Hope it helps,
Ed
Posted on Feb 01, 2009
SOURCE: I need to make PIONEER DVD player DV-310-K region free
I made it today,hurray!!!
Still need help??
Posted on Mar 09, 2009
SOURCE: How to setup Region code free for DVD LG DV 487
Power on the dvd player without any disc on it.
Press the PAUSE button and then the following numbers
3 1 4 1 5 9
Then you will be asked which region you want to set up.
0 = All regions. 1 = Region 1. 2 = Region 2 etc.
Then press pause again.
Then power off the dvd, and then turn it on.
I just did it with mine that was setup to only reagion 4 and couldn't watch region 1 dvds.. I set it up to = 0 (all).
Hope it helps.
Posted on Oct 04, 2009
SOURCE: pioneer DV 310 K region free
Step 1) Download the pioneer firmware here http://www.pioneerfaq.info/index.php?question=Firmwares
The site says the firmware only works on region 2 players. For this model it worked for my region 4 player in Australia
Step 2) Burn this file to a CD-ROM with name PIONEER as per these instructions - http://www.pioneerfaq.info/english/burn_guide.php
Step 3) Load the CD and your DVD player with ask you to flash the firmware. It says press play to start but instead HOLD DOWN ENTER during the entire process. DO NOT switch off your DVD during this time. When the tray opens take the CD ROM out but keep the DVD on. The flashing can take up two to three minutes. During this time HOLD DOWN ENTER ON THE REMOTE. The entire time!
Step 4) The DVD player will reboot. The tray should be empty. It will then load the tray back into the player. If the signal is disorted switch on and off.
Your done! Should work.
The most complex way of region freeing a DVD I have ever endured! :)
Posted on Jul 31, 2010
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
Jun 07, 2013 | Pioneer DV2032K All Multi Region Code...
How to change the Pioneer DV0-C503 DVD player from region one(US) to zero(region free) Thanks !
1) Turn on without any DVD inside.
2) push setup button.
3) go to general tab.
4) set the "Setup menu Mode" to Basic and leave the window that shows "expert" and "basic" options open.
5) press Display to see the actual region number.
6) press CONDITION MEMORY and then the Region number do you want to set.
7) press Display again to verify that the region have been set.
That should be it!
Feb 27, 2011 | Pioneer DV-C503 Multi-disc DVD Player
Pioneer model # DV-c503 will play DVD but does not play CD's anymore.
The problem could be dirt on the surface of the lens.
Use a dry cotton bud to clean the surface of the lens, this you have to do gently because the lens is fragile.
If otherwise you have to change the lens.
Try websites Shopjimmy.com,Ebay.com to buy parts for replacement..
May 28, 2010 | Pioneer DV-C503 Multi-disc DVD Player
A multi region DV-310 K stopped playing anything but region 2
Check your remote, try and see if you can find where you can default of restore first memory of your set. i think that will help........
Jan 29, 2010 | Pioneer DV-310 DVD Player
Need multi region hack code pioneer dv-220v-k
There is no need for region hack on this unit. It plays region free and all PAL dvd's out of the box without reprogram.
Dec 12, 2009 | Pioneer Televison & Video
Region code unlocking pioneer dv-220kv
My DV-220KV-K, which is sold as a Multi Region DVD player has locked up on me. The following message comes onto the TV screen...
(Player's Region Setting) <1> : Region <2> : Region <3> : Region <4> : Region <5> : Region <6> : Region Pick out any one of these!
The message remains on the screen ALL the time and I'm locked out of viewing anything. The remote is locked and so I cannot pick any of the region numbers!
Dec 08, 2009 | Pioneer DV-220V-K DVD Player
Pioneer DV 220-KV Need region free code please.
<1> : Region
<2> : Region
<3> : Region
<4> : Region
<5> : Region
<6> : Region
Nov 28, 2009 | Televison & Video
I live in germany and want to play dvd,s from Australia, Pioneer DV-360 from german store
Most DVD players I've seen are either multi-regional or one-region units. The DVD player you bought might be a one-region device. I'd check on that first. If it is, then you'll only be able to play DVD's made for that particular region. If it is multi-regional, look in the manual or go to Pioneer's website to possibly find the codes.
Jun 14, 2009 | Pioneer DV-360-S DVD Player
Pioneer DV-667A
Dec 13, 2007 | Televison & Video
Pioneer DV120K Player Logo
410 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
