I own a hp laser 2600n and for some reason it is not printing full colors on the edges.
  • 1,915 Answers
Faded color at the edges can be caused by 2 things.
1. A bad cartridge can cause an overload on the high voltage circuit and results in the print defect. If you recently changed a cartridge, it is the likley suspect. Try putting the old cartridge in. Often the yellow cartridge causes this for some reason.
2. Are you in a dirty environment or do you smoke around your printer. If so, the lenses for the scanners might be polluted, cleaning these requires a fairly extensive disassembly of the printer in order to remove the entire scanner assembly.
Posted on May 17, 2011
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
I am using the HP Laser Jet 2600n and I only use the black ink, I have it set up that way, for financial reasons. Why is it not letting me print? It is saying that my magenta is out, and will NOT let...
First of all, for financial reasons you don't use a color printer. Unless you print graphs.
Second of all, this is a laser printer, it doesn't use ink.
Third, all four toner cartridges must be inserted and working in order to print in any color.
Go back and read the "First of all" again and buy a B and W laser printer.
Dec 07, 2010 | HP Color LaserJet 2600n Printer
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
Magenta cartridge not working despite being full
This happens due to Laser sCANNER Contamination.
Light Output that typically starts fading along the outside edges of the media. The first noticable color would be Magenta.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach eazily.
Aug 27, 2009 | HP Color LaserJet 2600n Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
2600n prints greenish little reds
i have priner hp laser jet 2600n but it is printing very low any pic if i print it is come very low color i changed toner cart but still same problem.
Sep 03, 2008 | HP Color LaserJet 2600n Printer
Hp 2600n color printing problem
are you using orgnial hp cartridge if not check that it may cause due to that. check the black sheet fro color spreading , if there is any color pls clean that.........
Thank you
Feb 19, 2008 | HP Color LaserJet 2600n Printer
Re: printing
hi i have 2600n hp laser printer , I have changed Majenta Catrige with new one, but we have not get output for majenta color,
Nov 23, 2007 | HP Color LaserJet 2600n Printer
43 people viewed this question
jasbo
jasbo
