Question about Samsung HLP4663W 46" Rear Projection HDTV
Ok.....Samsung HLP4663 television makes a whining noise when we turn it on and then the sound of that whine diminishes. Recently after about two hours of watching the television the color on the screen goes to a greenish tint and there is ghosting of images. Is this a color wheel problem or or does the projection lamp bulb need to be replaced???
  • Samsung Master
  • 610 Answers
I would have to say that the color wheel is about to fall apart and should be replaced. You can call 1-800-samsung to find the closest service center.
Posted on May 17, 2011
Testimonial: "Thank you so very much....very helpful and quick...L :)"
MY SAMSUNG HLN 507 WX/XAA T.V. IS MAKING A WHINING SOUND WHEN I TURN IT ON
Your color wheel is going bad, when it fails the TV colors will be way off and it will shut down. They range from $50 -$125 . Here is one for $98 for your tv. http://www.amazon.com/Projector-Replacement-Samsung-HLN507WX-HLN567/dp/B00HJOLQ7G
Jan 09, 2015 | Samsung Televison & Video
Whining noise
your color wheel is going out. order a new one and come back to me I will walk you through the process of replacing it
Nov 27, 2013 | Mitsubishi WD-57734 57" HDTV
My samsun fp-t5084 is making a loud whining noise
its either a fan going out or power transformer. take the panel off and turn on the unit while being careful not to touch anything at all while power is to the device. plug it in and listen so you can identify the component. If its a transformer (it would more than likely be square and wrapped in a thick polymer sheeting.) it will be fine, possible for good. If its the fan making noise, you will typically have 9-12mths from the time you first here the sound before the perfomance is affected.
SO, to make a long story short, a hummming sound is typically the sound of electrical variations in a component, whining is normally a rubbing action within metal and plastic components.
(plastic on plastic makes a squeek, metal on metal a higher pitched squeek)
Jun 04, 2010 | Samsung FPT5084 50 in. Plasma HDTV
1996 chev k1500 whining drivetrain
It sounds like you differential gear noise by your description.
Mar 23, 2017 | 1996 Chevrolet K1500
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
Samsung HL-P5063W makes a whining sound and then goes off
The most common failure in the DLP that makes a whining sound would be the color wheel. They cost about $135 + labor because I wouldn't advise changing it by yourself.
Aug 02, 2009 | Samsung DLP HL-P5663W 56" TV
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Samsung HLP4663W 46" Rear Projection HDTV Logo
561 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
