Question about SCM Microsystems Inc. SCR3310 USB Smart Card Reader
Cant get scr3310v2 to read my dod smart card running windows 7 home premium version 6.1 s3xxx64. sys version 4.49.0.0 installed ctpcsc31.dll version 2.52.0.1 installed mcscm.dll version 4.1.0.0 installed firmware: v2.04 driver: v4.49
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
Regsvr32 error goopdate_unsigned.dll
try downloading Quick Heal Total Security from internet you can download trial version for one month install it register it update it and run antimalware and if possible try to boot scan it
Apr 18, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Missing binkw32.dll
Download binkw32.dll from link and save it to your Hard Drive.
2. Copy binkw32.dll file to C:/windows/system32
3. Overwrite if asking.
4. If you still getting error - copy the dll file also to your software/game folder.
http://www.dll-files.com/dllindex/dll-files.shtml?binkw32
scroll down and click DOWNLOAD ZIP-FILE
Nov 06, 2013 | Microsoft Windows 7 Home Premium for PC
Where can I get a free download for windows xp 3 ksuser.dll?
The ksuser.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, ksuser.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not download the ksuser.dll DLL file individually from any "DLL download site." There are a number of excellent reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded ksuser.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
1. Restart your computer if you haven't yet.
The ksuser.dll error might be a fluke and a simple restart could clear it up completely.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the ksuser.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the ksuser.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with ksuser.dll and a reinstall could do the trick.
5. Restore the ksuser.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your ksuser.dll error, try extracting the ksuser.dll individually from the DirectX downloadable package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Oct 30, 2012 | Microsoft Windows XP Home Edition Service...
I would like to install 3D Home Architect 3.0 Deluxe on a computer running Windows 7. I've tried a few fixes I found on-line w/o sucess. Is this possible? If so, how? Many thanks.
1. Change the Settings of the Program:
  • Start
  • Control Panel
  • Programs
  • Run programs made for previous versions of Windows
  • select "Next", "Not Listed", "Next", "Browse" and locate 3DHOMEV3.EXE on your HD.
  • select "Open", "Next", "Try recommended settings", it will pick the recommended settings, select "Next
2. Copy missing dll's:
  • Search for the following files in the 3D Home Architect Installation CD and copy them to C:\Windows\System
  • D3DRM.DLL
  • D3DRM8F.DLL
  • D3DRM16F.DLL
  • D3DRM24F.DLL
  • D3DRM32F.DLL
Hopefully this will help you too! Good luck :)
Sep 12, 2010 | The Learning Company 3D Home Architect...
Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Microsoft Office 2007 Basic for PC
Which version of windows 7 goes with primavera 6
It works with Win 7 Ultimate, but it should work with all versions -you need to install SQL Server SP3 BEFORE running P6 for the first timethough...
SQLServer2005SP3-KB955706-x86-ENU.exe
Nov 17, 2009 | Primavera Project Planner P3 (PRIMAVERAP3)...
Catastrophic failure reported by operating system - Vista home pr
Try this..
START button > RUN
Type in or Copy/Paste from here into the command line...
REGSVR32 JDBOLEDB.DLL
This will try to register it. If no error messages pop up it's been added.
To unregister it do... /u
REGSVR32 /U JDBOLEDB.DLL
Nov 24, 2008 | Microsoft Windows Vista Home Premium with...
Problem while installing Logitech webcam software in Vista Home Premium
If you are using windows xp then you should download this fix from the microsoft website. http://www.microsoft.com/downloads/details.aspx?FamilyId=C717D943-7E4B-4622-86EB-95A22B832CAA&displaylang=en
If you are running windows vista please follow these instructions carefully.
  1. Click on "Start".
  2. Click on "All Programs".
  3. Click on "Accessories".
  4. Right click on the Command Prompt, select "run as administrator".
  5. At the prompt, type "regsvr32 vbscript.dll".
  6. You will now get a message box saying "vbscript.dll" has been registered.
  7. Reinstall QuickCam
I hope this helps. If not let us know.
Please rate my answer
Jan 07, 2008 | Logitech Webcam
Computers & Internet Logo
154 people viewed this question
Top SCM Microsystems Inc. Computers & Internet Experts
David Payne
David Payne
Are you a SCM Microsystems Inc. Computer and Internet Expert? Answer questions, earn points and help others
